LSJ or 2.4 Throttle body?
I seen this adapter kit to run Lsj throttle body from zzp. do you think this would be a smart idea? im just wondering if it would be a good if I ran Lsj instead of the 2.4 tb on all motor. im also going to be running cams
This. Lsj is way too much. I'd explain it with datalogging info from a run I recently did but most people wouldn't understand. LOL. I basically ran 1.08 g/cyl for a very short amount of time just with the 2.4im/tb.
hard decision and very confusing. I read other threads, other people saying it was good. maybe ill just use a 2.4 since I hear so many good reviews about that. think one guy said with lsj throttle body his 80 - 100 was faster. im guessing you will loose low end torque to gain that? and that what people are feeling?
You auto trans?
That wiring harness is to adapt the LSJ 8-pin to 05 and 06 8-pin 2.2 models only. If you want it on yours you'll have to repin your own stuff. Your throttle body is 6 pin. 0-100mph(on a closed airport runway) is about 25 seconds for me. 0-60 in a little under 8 seconds on a cool day and 8.7 seconds on a hot day. It's not braggable but it's fun and respectable. You'll be happy with the 2.4TB. the LSJ is more of an upgrade for a 2.4.
yes that's what I was looking at. the guy at zzp said I could use the 6pin to 8 pin connector on my 07 with 6 pin tb. is this not right? ill probly go for 2.4 tb. but what I want to know is the adaptor is just ordered a waste lol. there is a 6 pin to 8 connector on there site?
well this is very confusing than lol. im hearing 2 stories now. he said as long as I have a 2.4 intake manifold preferably a 07 2.4 intake manifold. and my stock tb is 6 pin. I could use 6 pin to 8pin lsj throttle body. probly not worth the trouble. probly cancel my order.
EDIT: Looks like they have come out with a 6-to-8pin adapter. ****, where was that a year ago? Lol. LSJ TB is still too much for 2.2 though.
I got it $65 used on ebay. it seems to look different then the 07 2.4 intake manifolds that ive seen on the cobalts from the pics. guess I will be testing both, a 07 and 08 2.4 intake manifold
Its a 06. I will probly use trifecta once I get a tb. since I already have a tune. so I guess it will just be a tune update. do you think I should get a 2.4 tb from a 07 or 08 since 08 I believe has 6 pin? or maybe this zzp 6pin to 8pin I ordered also might work for 2.4 8 pin tb?
Lol ignore my post before this. If your car is a 2006 it has the 8 pin throttle body. Get whatever matches your car.
Sorry.
