Mandrel Exhaust & Eibach Suspension
Old Sep 28, 2012 | 12:17 AM
Cruzzer38's Avatar
Question Mandrel Exhaust & Eibach Suspension
I'm thinking of ordering from Mandrel Exhaust, I've seen mixed reviews (some hate em some love em) and their prices are really good. I'm lost on the difference between 2 bolt flange and 3 bolt flange? I was told only the TC had a 3 bolt flange but I just wanna know what that means. They also offer borla, magnaflow, or vibrant mufflers... which one would have the deepest tone and sound least like a ricer? (I hate those fart can sounding cars) Theres also an Eibach suspension kit for about 470$. I'm not looking for an autoX champ suspension setup, but will this be good enough to make the corners and windy roads feel more firm? And I'm stuck on whether I should get an injen, weapon r, or k&n intake. I did wanna short ram but now I'm leaning more towards cai just from what ive been reading. Any suggestions?
Old Sep 28, 2012 | 12:36 AM
bluebalt07's Avatar
You can see the flanges here. Bottom right is the flange for any non TC cobalt catback. The ss/tc has the 3 bolt flange next to it.
As for mufflers on the catback, my magnaflow is very loud and sometimes raspy but I'm catless and supercharged.
Suspension, are you talking about just the springs or the sway bars as well?
Old Sep 28, 2012 | 12:51 AM
Cruzzer38's Avatar
Well I'm just a 2.2 LT, so you think I'd be fine with the magnaflow? I dont want it too be obnoxiously loud, and as for the suspension, i found i could get the eibach pro springs (lowers 1.6 in' for the front and 1.8' for the back) and the anti roll sway bars for the rear for $440, are both neccesary for a firmer ride??
Old Oct 4, 2012 | 09:13 PM
Cobalt08LS's Avatar
get the powell hardcore sway!
i have sportlines for sale if you wanted to buy them
Old Oct 4, 2012 | 11:06 PM
BLKLS's Avatar
NEPA, is close enough to me that I can tell you I have a set of eibach sportlines and I am not super happy with them. I knew these would not be the best choice but I expected more. They are pretty good for daily driving, but when you start hitting uneven back roads the get a little unsettled. As for they're swaybars save your money. If you are close enough to bucks county and wanna meet up and feel the ride hit me up.
And go with a short ram, car drive better.
Old Oct 6, 2012 | 08:29 PM
Cruzzer38's Avatar
BLKLS sounds sweet man. And yeah I think I'm gonna go with the k&n typhoon sri. Im gonna do the tb nd i.m. first tho (getting them shipped for 235$) then from what I've been told through the forums my money would be best spent on a cat back. I found a pacesetter for 260-ish but its not stainless, and I've been told by some that i'll be fine and others said it'll rot out quick...
Old Oct 6, 2012 | 08:44 PM
bluebalt07's Avatar
Anything that isn't stainless is a waste. Stock catback is stainless and it is for a reason. Stainless helps exhaust flow by keeping the heat in and obviously it also doesn't rust off.
Old Oct 6, 2012 | 08:46 PM
Cruzzer38's Avatar
I was told the cobalts stock exhaust isnt stainless??
Old Oct 6, 2012 | 08:59 PM
bluebalt07's Avatar
Stock exhaust is 409 stainless, same as many aftermarket catbacks. I think ZZP is the only one with a higher grade stainless and it's 304. Don't know the difference exactly, but my catback is 409 stainless and has some surface rust, my header and downpipe are 304 stainless and have absolutely zero rust even after going through winter. The only way you can even tell they are used is because they have discolored from the heat
Old Oct 6, 2012 | 09:10 PM
chevygirl2006's Avatar
dont get pacesetter. ive had mine under a year and the muffler is rusted a it has holes and cracks
Old Oct 6, 2012 | 09:16 PM
CobaltLs505's Avatar
About intake I suggest injen cause u can switch from cold air and short ram intake any time and catback I try to find a used gmpp or go with borla
Old Oct 6, 2012 | 09:18 PM
breds2k's Avatar
Just get a cheapo ebay catback!!! had mine for 9 months and love it paid $160 shipped! fit perfect!!! And Eibach pro kit (unless sportlines) does NOT drop a base model very much, I think you might be disappointed, seems like the most liked spring on here is the CM Springs (Canuck Motorsport) I believe they are under $200 and ride ok, and have a good drop.
Old Oct 6, 2012 | 09:30 PM
Omnigear's Avatar
get the stock tc spring and fe5
^_^
Old Oct 6, 2012 | 09:35 PM
cm springs ride better than ok and they are 180 shipped
Old Oct 6, 2012 | 10:00 PM
bluebalt07's Avatar
Love my cm springs. A little firmer than stock at first but not uncomfortable and for the price you can't beat the drop and the better handling.
Old Oct 6, 2012 | 10:15 PM
yup!
Old Oct 6, 2012 | 10:42 PM
BLKLS's Avatar
Dude, lsj catback and zzp longtube. All you need.
Old Oct 9, 2012 | 01:38 PM
Cruzzer38's Avatar
That'll work on my LT?
Old Oct 9, 2012 | 08:29 PM
BLKLS's Avatar
Yep. I got the long tube with a 2.5 exit, bolts right up to the lsj exhaust. Loud when your on it. It quiet enough to drive everyday, no drone. Mine tends to bang where the exhaust goes over the axle on the body of the car, mostly when the AC is on at idle. I think it's cause the 2.5 exit on the header is a little longer then the 3 inch. Not much you can do about it. I have an ls. Fits fine.
Old Nov 9, 2012 | 04:21 PM
iToastie's Avatar
I've got a Mandrel Exhaust w/ Borla muffler, it sounds sex
Old Nov 9, 2012 | 10:14 PM
BankerBalt's Avatar
08-10 SS Fe5 shocks and struts are a must if you want a firmer ride. Along with new strut mounts. That eibach kit is a rip off. Buy some ssc springs from zzp and either a Powell or ttr rear bar if you really want a rear bar. If you decide to put a bigger front sway bar on or not, moog endlinks for the SS Fe5 suspension are a nice improvement also. Stock cobalt exhaust systems are not stainless steel either
Old Nov 11, 2012 | 07:05 PM
Cruzzer38's Avatar
Thanks for the tips BankerBolt, nd toastie is it deep? Cuz like isaid I hate those shitty civic fart cans
Old Nov 11, 2012 | 09:59 PM
iToastie's Avatar
Yeah it's actually the deepest N/A four cynlinder exhaust Ive heard.
You can drive and not be embarrassed
Old Nov 11, 2012 | 11:23 PM
Cruzzer38's Avatar
Well I'm lookin to get an LSJ catback for like 70$ if not it'll be down to tsudo or mandrel bent
Old Nov 11, 2012 | 11:24 PM
magnaflow sounds really good with the zzp catted downpipe and the badmab header
