My S/C Setup
Old Apr 5, 2009 | 07:23 PM
scott allen's Avatar
nope i need them.
Old Apr 5, 2009 | 07:50 PM
06_ion2's Avatar
Originally Posted by Dayta
79s are overkill imo
nope ill be running them in my 2.2
Old Apr 5, 2009 | 08:08 PM
Geoffery Kennedy's Avatar
let see some pics
Old Apr 5, 2009 | 08:11 PM
glen229's Avatar
Originally Posted by 07cobaltguy
well i never made a build thread but im pretty well finished, im pushing the stock block pretty far. Here are my mods. Tommorow is race day, so 1/4 mile times and vids should be up tommorow night.
Thanks goes out to vince for pulling through and getting my tune here and dialed in today (day before race day)
Mods:
Eaton M62
Dual Pass End Plate
OTTP Heat Exchanger
Vibrant Header and Catless Downpipe
Injen Intake
Edge 60lb injectors
AEM Wideband
Megan Racing catback
Stage 2 Pulley @ 16psi (w/ 7k redline)
7k Redline
how?
Old Apr 5, 2009 | 08:19 PM
not bad
Old Apr 5, 2009 | 11:08 PM
HunterKiller89's Avatar
Originally Posted by glen229
how?
its called a tune
Old Apr 6, 2009 | 11:25 AM
07cobaltguy's Avatar
I'll get some pics up later, my weekend got real busy. I ran a 14.009@102.89 14.197@105.9 14.020@104 then a 14.197@97 <--- that probably would have been a 13 second run but i forgot where i was on the track and let off early.
My 60' times suck ass *****, 2.4-2.5, best i cut was a 2.2. that 14.020@104 was my very first run of the day. My blower is heat soaking bad, so im sure with cooling mods and another retune, and my DR's 13's will be had.
Originally Posted by 06_ion2
you got filled mounts???
Ive got the red poly bushings, no wheel hop at all.
Originally Posted by BLKLS
yeah whats the 60' numbers?
are you still running the stock clutch?
my 60' times sucked as stated above.
yes i am stock clutch i have yet to have it slip..... knock on wood.
Last edited by 07cobaltguy; Apr 6, 2009 at 11:25 AM. Reason: Automerged Doublepost
Old Apr 6, 2009 | 11:28 AM
stenguyen1's Avatar
i was gettin 15 psi on my blower before we tuned it down to 13 psi.
Old Apr 6, 2009 | 03:05 PM
glen229's Avatar
Originally Posted by HunterKiller89
its called a tune
how do you tune a supercharger setup to make higher boost?
haha maybe hes gota clogged cat at 16 psi
Old Apr 6, 2009 | 03:07 PM
stenguyen1's Avatar
you can run more fuel than it will get you more boost. i think....
cuz when i was runnin too much fuel i was runnin 15psi and now that i'm runnin right i'm runnin only 13 psi. so that could be it. but idk. you could ask vince
Old Apr 6, 2009 | 03:09 PM
  #36
Perfect.disguise's Avatar
Nah, if you went from 15psi to 13psi on the same pulley then your bypass valve is tuned to limit it to 13psi.
Old Apr 6, 2009 | 03:19 PM
  #37
Jn2's Avatar
Jn2
ona 2.2 the bypass valve is not wires to anything, there is electrical controller of any sort, its mechanical, not electrical, i know on the stock 2.0 it has a small electrical controller thingy, we dont use that
Old Apr 6, 2009 | 04:14 PM
  #38
well, if he's revving to 7,000rpms, and our cam profile limits flow after 6200rpms, then hes seeing such high psi because at those rpms the profile doesnt allow enough time for air in the manifold to enter the cylinders, so it all builds up in the manifold instead, and whala: additional boost
Old Apr 6, 2009 | 05:01 PM
  #39
stenguyen1's Avatar
well idk. i was just saying thats how my car was when vince looked at it and i drove it. but everything is hooked up great.
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
ThoR294
Oct 4, 2015 08:44 PM
cw383
Sep 30, 2015 12:41 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
