need help
need help
so last night my car ***** the bed i threw a cel for a misfire so as im changeing the plugs one of them is bent and looks smashed up i have no clue what would cause this any help would be great the whole car is vibrateing and putting has any one went through this b4 the car is a 07 ls now i changed the plugs and it idles fine but i tryed to drive away and it started vibrating and when i gave it gas it stalled out i should probably mention that the past 2 weeks i have been getting a cel for running to rich
[IMG]
[/IMG]
[IMG]
[/IMG]
What do you have done to the car? What were you doing when the CEL came on? What type of plug? Is the bad plug black or white or another color? Does it look like any pieces of the plug are missing?
Chances are whichever cylinder the problem occured in is toast.
Smashed plug = either detonation or the piston hit the plug. It is uncommon for a plug to just "break".
thats what im saying i dont think the plug bent at idle though it started vibrating really hard and i had no way to get home so i tryed to drive it thats when the plug bent i think and i had the stock plugs in the ac delco ones
Are you running any mods? NO2? CAI? A CAI can cause a too rich code, especially if there is a leak after the MAF. If you are running NO2 or a SC or turbo you should probably be running a colder plug then the stockers.
Hmmm... sounds like you may have lost compression or the plug fouled 2 weeks ago. I would do a compression test on the cylinders and see if they are still holding compression. If #3 has lost compression it is time to do a rebuild. If all the cylinders, especially #3, are still holding compression you maybe lucky and if the plug was actually fouled 2 weeks ago you may have just ruined the CAT.
I totally missed where the mods were listed... sorry... lol.
Is the black on the plug oily or powdery?
It looks like you are running WAYYYYYY rich or you are leaking ALOT of oil into that cylinder. Judging by the damage to the plug, you definately need to do a compression test and pull the head off. I don't think the piston hit the plug, but it looks like something may have been loose in the combustion chamber. You may have chipped a piston or it maybe the rings... hard to really tell without taking a look inside. I can't tell much else because the plug is fouled too badly, but it looks like the plug might have been too hot as well.
You have two options.
1. Remove the NO2 system, remove the CAI and put at least the stock header or LSJ header back on. Then, take the car to the dealer and try and get them to check it and fix it under warranty.
2. Tear the engine apart or take it to a shop and have them tear it down and check it out. More than likely you are looking at having to do a rebuild, at least on that one cylinder.
im deffanetly a he my gf took the pics lmao i told her that someone would think i was a girl
the plug had a powdery black on it my guess is its carbon all of them were like that i am going to do a compression test tomorrow now that i changed the plugs the car idles fine but when i tryed to drive home i got a block down the road and it died out it sounds like a wrx right b4 it dies out
If it sounds like a WRX chances are there is damage somewhere. Either pistons, rings or maybe a valve.
If it is sooty black then you are definately running WAY rich. It is normal to have a little carbon around the edges, but not that much.
