OBX 2.2L header
Old Aug 6, 2008 | 10:23 AM
Whitty's Avatar
OBX 2.2L header
i was looking around in past 2.2 threads and came across the OBX header. It says on ebay that it is a bolt on replacement with no modification. but in a previous thread it was said that it is a pacesetter knock off and that would require cutting the DP to make it fit. so which is it is my question lol. Also in the picture the OBX looks like it has a 2 bolt collector and the stock is 3 ? wtf? has anyone installed this yet ?
Thanks so much!
here is the auction for it.
http://cgi.ebay.ca/OBX-Stainless-Ste...ayphotohosting
Old Aug 6, 2008 | 10:27 AM
Spanky's Monkey's Avatar
the obx header needs the obx downpipe or you will need to modify the header to fit. i'd say get the dp too anyaway you'll get better results with both.
Old Aug 6, 2008 | 10:29 AM
Whitty's Avatar
i need to have a cat here tho. so thats my issue OBX doesn't make a header DP combo with a cat and the position of the O2 sensor means it would get cut out with the addition of a cat which makes for custom work at a shop to add another 02 sensor hole.
Old Aug 6, 2008 | 10:38 AM
you could also use an aftermarket dp with the 2 bolt flange, but good luck finding that at a good price. most muffler shops want an arm and a leg for cats.
get a magnaflow cat for $80 and pick up the right flanges and get a shop to mandrel bend the piping the shop cost including bung placement shouldnt be more then $80.
hey there why not get tuned and eleminate the cat codes so you can just use a catless dp?
Last edited by Spanky's Monkey; Aug 6, 2008 at 10:38 AM. Reason: Automerged Doublepost
Old Aug 6, 2008 | 10:40 AM
Whitty's Avatar
cant go cat less where i live that why its an issue. Also i have been to every shop in my area and no one deals in mandrel stuff... so it would be compression bent if anything...
Old Aug 6, 2008 | 10:44 AM
can you get to the states? i'd highly suggest getting the mandrel bend cause compression will kill the header performance period. either that or pony up for a header/dp combo that includes the cat, they're expensive but it'll be well worth it.
Old Aug 6, 2008 | 10:58 AM
Whitty's Avatar
yah, might have to i guess i dont have that kinda money right now guess i should save and do it tho. lol what about getting a shorty header and matching it with the SS/SC DP that would get some decent gains ?
Old Aug 6, 2008 | 11:19 AM
the lsj dp is gonna restrict airflow.
Old Aug 6, 2008 | 11:32 AM
Whitty's Avatar
not compared to the 2.2 lol
Old Aug 6, 2008 | 11:49 AM
tru2nrtt777's Avatar
but it will still be the bottle neck to your application.
Old Aug 6, 2008 | 11:55 AM
Whitty's Avatar
yah thats true... so what would u guys suggest as a combo then vibrant? (lot of money but might do it...) or ZZP mid length or what ?
Old Aug 6, 2008 | 12:07 PM
MadBrad's Avatar
Ask Jn2 what he did.
either one will be a good buy.
Old Aug 6, 2008 | 12:21 PM
Whitty's Avatar
right on guys thanks ill look into Jn2
edit: is all he did was beat the coolant line out of the way to fit in the header DP ?
Old Aug 6, 2008 | 09:29 PM
wbrevels's Avatar
thats what i plan on doing, i was also looking at OBX heads and realized the 2.2 are long tubes where the 2.4l are midlength and comes with a catless DP for the same price.... the 2.2 "will bolt right up" and the 2.4 will need whacking of the coolant line, i'm gonna go with the 2.4 on my2.2 because it comes with a downpipe to complete my full exhaust, once done i'll be posting vids in the 2.2 section, i should get the exhaust in a week and hopfully the head/dp soon afterm within 1-2 weeks.
sucks you can't go with the 2.4 and get the DP because of your cat laws
Old Aug 6, 2008 | 09:35 PM
will the header not fit from below? i don't like the idea of whacking anything that has to do with cooling the engine or myself for that matter.
Old Aug 6, 2008 | 10:43 PM
Jn2's Avatar
Jn2
i made a review for this thread, it is not a direct replacement, search for the obx thread, i will post it, give me a minute
https://www.cobaltss.net/forums/show...ght=obx+header
i make the htreads 4 u to read them
the obx 2.4 will fit, but you will have the whack a coolant line, its a hard one, so no problem...ill post a pic of it in a bit, the header goes in fine from the top and bottom, but the #4 primarie will touch the line, and it wot let you position the header on completely, you have to whack it a bit to scoot it over to the right...than it will fit, the OBX the OP postes will connect to the head fine, b ut you will have to cut ur stock dp right at the top of the CAT...
here is a pic of the OBX compared to my vibrant, the vibrant also has the same fitment issue from the coolant line,i outlined the line i am talking about, and on my vibratn you can see the whack marks i left, but the line can take it
Old Aug 7, 2008 | 02:20 AM
wbrevels's Avatar
Jn2, maybe you could help me out, i'm a bit confused after reading your post about th eOBX header, i heard that the 2.4L will bolt on if you smack the coolant line, would i be right in saying go this route because it come swith a downpipe, that way you want have to cut your stock dp and weld, it would just be a full bolt on? correct me if i'm wrong, you have me scared of getting heads now because it rewuires cuutting and welding. the 2.4 OBX heads come with downpipe and the 2.2 dont, thats why i ask
Old Aug 7, 2008 | 02:47 AM
HyphyDrivah's Avatar
What is ebay.ca?
Old Aug 7, 2008 | 03:37 AM
wbrevels's Avatar
ebay canada
Old Aug 7, 2008 | 09:02 AM
Whitty's Avatar
thanks for all the help guys i think i am just gonna save my pennies over the winter and get ZZP or vibrant. Guess i will have lots of time to decide and save up lol
Old Aug 7, 2008 | 10:28 AM
wbrevels's Avatar
hmm, i'm going with the OBX 2.4l head/DP combo for only $265 shipped off ebay, grea price for the parts for my 2.2, i wouldn't want to spen $400-500 on head/dp
Old Aug 7, 2008 | 11:02 AM
Switt23's Avatar
Are there any negative side effects from moving the Coolant line out of the way? I cringe at the thought of beating the line with a hammer, but if it's not gunna have any negative side effects, I suppose a rubber mallet doesn't sound too harsh.
My header has an exhuast leak and if i'm ripping it off to replace the gasket, I might as well upgrade.
Old Aug 7, 2008 | 04:03 PM
Jn2's Avatar
Jn2
there is no negative effect, you wont even notice, and your nly scooting it over maybe a 1", and do it slwly not by one big smack...
look at the pic i posted in page 1 at the bottom, the OBX didnt require moving it and the vibrant did, and like i told the OP, he might have to move it if he gets the 2.4" header, no sure, just assuming for the worst case scenerio, thats the worst that could happend, and its a easy fix
hacadacalopolis
Oct 28, 2015 06:09 PM
ThoR294
Oct 4, 2015 08:44 PM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
