oil
Old Mar 9, 2010 | 05:31 PM
fupaNINJA00's Avatar
oil
?people that have a 2.2 with a stock supercharger from the SS. which oil should they use?
Old Mar 9, 2010 | 05:32 PM
mkulrey13's Avatar
you can get the supercharger oil from CED a vendor on here. For the motor, mobil 1.
Old Mar 9, 2010 | 05:35 PM
is that synthetic?? i just take it to the dealer cuz with my oil they do a 14 point check.. but now that i think about it i don't think they put oil in the supercharger...
last time he was just like, "normal oil?" it happend so fast i just said YES
Old Mar 9, 2010 | 05:51 PM
blackbolt89's Avatar
if im not mistaken the s/c oil lasts quite a bit longer than motor oil. so the dealershit probably didn't change it anyway.
GM sells special supercharger oil i believe too. so if you wanted the convenience of going to the dealershit and buying it there without having to deal with ordering it they should carry some.
Old Mar 9, 2010 | 05:54 PM
and engine oil? is the mobil one synth. or not?
Old Mar 9, 2010 | 06:25 PM
motor oil that came in the 2.2 was dino oil. conventional.
i use mobile 1 5w-30 which indeed is synthetic.
i wouldn't worry too much for now what oil you got in the motor, just swap to synthetic next time if you really want to.
just make sure to think through your answer next time to the tech guy lol. it should be fine for now though.
Old Mar 9, 2010 | 07:26 PM
tmharsh's Avatar
When I had a GTP I believe I generally changed the supercharger oil every 30,000 miles. I would assume the Eaton on Cobalts would use the same oil. I've used both the GM supercharger oil and the oil that ZZP sells, which I believe is the same stuff.
Old Mar 9, 2010 | 08:14 PM
jmz250's Avatar
^^What he said...every 30,000 miles on the supercharger and you should be good. Definitely run a full synthetic next time. The stock SS/SCs require it, so you should use it for your app too.
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
