Oil leak ?
So my wife has a 2005 coblat sedan automatic. And lately i cant seem to keep oil in it. It has an oil leak that seems to be dripping from some where in the front of the engine. Towards the bittom of the block. It looks like it is running onto the starter and then drips onto the ground. At first i thought it may be the oil pan or oil pan gasket. But it doesnt look like the leak from there that i can tell. Almost like it is coming from something else. I guess my question is , is there anything on the front of the enfine that could be leaking oil ? Like an oil level sensor or pressure sensor ? Maybe if there is something on the front of the engine just aboce the pan around the starter area it may have a bad seal ? Any ideas ? I was hoping people more familiar with the 2.2 could help me out. If it was my ss/tc i would have a better idea.
Yes... It seems to be deipping off the starter . but i cant seem to see an exact source of the leak. I was wondering if anyone knows if the oil level sensor is around there ? Or the oil pressure sensor ? Something ? Because she drips a litre a day. Lol
I would check the O-ring you are supposed to replace every oil filter change and the oil filter cap itself and make sure everything is good there.
I took a quick look at that first. And it doesnt appear to be leaking . Not that i i can see anyhow. I will double check it again just to make totally sure. That would be sweet if thats all it was. However. In the 5 years i have owned my lnf. I have never replaced that o ring. And no leaks . Worth a check though.
So i found where the leak is. There is a sensor at the bottom of the intake mani. To the right of it. Just above the starter. It is a one wire sensor. I assume it is the oil pressure sensor. The oil is leaking out where the harness plugs into the sensor. I unplugged the sensor and it is full of oil inside of it. I started the car up with it unplugged. And it is deffinitly leaking from there. So i cleaned it up. Threw some seal all on it. And will hope that either stops it totally or at the very least slows it down until i can get a new sensor and pull it out of the block and put a new one in. Anyone ever change that sensor and know exactly if its oil preasure or oil level ?
Alex S
41
Mar 18, 2016 02:20 PM
