Oil pressure gauge install
Old Apr 4, 2011 | 11:01 PM
redcobalt07's Avatar
Anyone know the spot on the block where you install the fitting to send oil to an electric sending unit? A picture would be helpful.
Old Apr 4, 2011 | 11:02 PM
hook's Avatar
Give me 2 min lol
Old Apr 4, 2011 | 11:06 PM
Thank you very much.
Old Apr 4, 2011 | 11:07 PM
hook's Avatar
05Slowline's Avatar
same spot front and back, to get them out easily take a hand torch and heat up the bottom where it molds into the block for a minute or two to heat up the loctite then a t-40 male torx will get it out.
Old Apr 4, 2011 | 11:08 PM
hook's Avatar
Mine is on the right side of the motor.
Old Apr 4, 2011 | 11:09 PM
05Slowline's Avatar
guess you don't use the same thing as you do a feed line lulz
Old Apr 4, 2011 | 11:11 PM
does it matter if I have a 2.2 vs your 2.0 slowline?
Old Apr 4, 2011 | 11:12 PM
hook's Avatar
My gauge reads fine tho? And I looked up on all data where to tap in. Works fine
This? Mine is 2.2 l61
Old Apr 4, 2011 | 11:13 PM
Ah ok good. So it is on the right side of the engine when looking at it. Do you have any zoomed out pictures?
Old Apr 4, 2011 | 11:15 PM
05Slowline's Avatar
No I wasn't saying you were wrong hook haha I figured you drew for it the same place you did for a feed line looks like you don't though. and all the ecotecs have the galley bolts.
Old Apr 4, 2011 | 11:18 PM
hook's Avatar
You lost me lol. Are you saying that the sensor looks out of place and a live oil line looks better coming from the galley?
Old Apr 4, 2011 | 11:19 PM
Hook do you have any better pictures or some zoomed out ones?
Old Apr 4, 2011 | 11:20 PM
hook's Avatar
I'll post you a few in the morning my man
Old Apr 5, 2011 | 12:14 PM
hook's Avatar
Pictures in 30 min
Old Apr 5, 2011 | 06:30 PM
05Slowline's Avatar
Nah the galley bolt I pictured is what's used for turbo oil feeds I assumed it was used for the oil pressure also, looks like it isn't lol.
Old Apr 5, 2011 | 08:28 PM
hook's Avatar
And why are my pictures not up lok
Old Apr 5, 2011 | 08:29 PM
05Slowline's Avatar
show up for me
Old Apr 5, 2011 | 08:37 PM
iboost's Avatar
sub'd for when I hook up my oil temp gauge
Old Apr 5, 2011 | 11:34 PM
The brass thing is the fitting
Old Apr 5, 2011 | 11:38 PM
LS6Rally's Avatar
I dont have one of mine, but im in the same place as Hook on my 2.4. its on teh outside of Cyl. 4 right above the Trans Case. you take out the Plug (Allen Key) and screw in the adapter and the sender. USE THREAD TAPE!
Old Apr 6, 2011 | 08:14 PM
Do you have pics? That pic I posted is from a 2006 and it looks a bit different than mine.
Old Apr 7, 2011 | 06:20 PM
stenguyen1's Avatar
great thread. helps out everyone.
Old Jul 12, 2011 | 11:22 AM
organic E's Avatar
you can also use the galley plugs on the back of the motor also right? i had seen pictures that people were using the plug behind the water pump? other question there are about three plugs on the back of the block, does anyone know if they are usable for gauges?
Old Jul 12, 2011 | 11:42 AM
mr.saab's Avatar
this is where i have mine, Photo not mine
