pacesetter catback owners
Old Oct 8, 2006 | 08:51 AM
That Cobalt LT Guy's Avatar
I just put a pacesetter catback on my LT and it has this nasty burning smell I have put over 200 miles on it since instalation and it still smells Im wondering if this is normal and how long will it last
Old Oct 8, 2006 | 09:12 AM
Mercury's Avatar
Your exhaust might be touching the heat wrap over the fuel lines. Check where the exhaust pipe goes over the rear crossmember and bends upward. I think you might see that the exhaust is touching something and burning it away. You might not have replaced the correct exhaust hanger with the one they provided.
Old Oct 8, 2006 | 09:15 AM
D4u2s0t's Avatar
bad smell is a normal part of a new exhaust, it will go away... basically it comes down to running very hot gasses through a pipe, and everything is being burned off it... glue, paint, grease, etc... will go away... could take anywhere from a few days to a few weeks depending on how you drive... it's not really so much about the mileage as it is how long you drive each time
Old Oct 8, 2006 | 09:18 AM
its not touchinhg any heat wrap I did use the right hanger the.
I just tryed to detemine were it was coming from and its coming from the inside and the outside and smell realy bad at least no one tail gates me any more.
Old Oct 8, 2006 | 09:21 AM
D4u2s0t's Avatar
like i said above, it's totally normal... it will go away soon... did you take the stickers off the pipe? i know mine had a few on there
Old Oct 8, 2006 | 09:31 AM
I just left them on could that be makeing the smell and how long did your pacesetters smell for
Old Oct 8, 2006 | 09:37 AM
Mercury's Avatar
Mine smelled for about a week. although I push more exhaust through since I have the SS/SC.
Should only be about a week for you though
Old Oct 8, 2006 | 09:43 AM
ok I guess that i Will just have to deal with it for now.
Not to be rude and change the subject but does the pacesetter have a breakin period were The sound will change as it breaks in. And will the car sound better with a cai.
Old Oct 8, 2006 | 10:03 AM
Stilgar's Avatar
I like how cheap that exhaust is, but it does not sound that good.
Old Oct 8, 2006 | 10:05 AM
D4u2s0t's Avatar
have you actually heard one?? or just on the web... because i love my pacesetter sound, and every other person here that i know of that has one loves it as well... i think it sounds great...
anyways, yes, take the stickers off if you haven't already... those are slowly baking off and will leave a nice black residue
Old Oct 8, 2006 | 10:07 AM
D4u2s0t's Avatar
the ehxuast threads are great in theory, but you hvae to remember that it's going to sound a LOT different in person... anyone that makes videos (i do it for a living) know that the sound changes after recording it, unless you have proper microphones and equipment... the online sound clips don't do any of the exhausts justice
Old Oct 8, 2006 | 10:08 AM
I think it sounds very good its deep very deep at idle you have to here it in person the videos lie it worth the $200 if you dont like it then move up ($) from there. also at the high rpms there a litle rasp between gears u can getrid of this with a resinator.
Old Oct 8, 2006 | 10:09 AM
D4u2s0t's Avatar
i have the auto, and there is zero raspiness/ricerness, even at full throttle...
Old Oct 8, 2006 | 10:13 AM
I have an auto to but for some reason my auto shifts harder than most(cherps the tires going to second) and theres a little rasp.
I raced another LT and my car shfted harder and faster than there's back when I was stock.
Old Oct 8, 2006 | 10:17 AM
Stilgar's Avatar
I heard Mercury's SS with, he just put it on so it wasn't broken in yet. I suppose I could always go with a different muffler like Borla or Magnaflow.
Old Oct 8, 2006 | 07:39 PM
huliehan's Avatar
what would be the best exhaust system for 06 ls model
Old Oct 8, 2006 | 08:04 PM
1SloBowtie's Avatar
There's not going to be much of a sound change over time. The muffler is all metal, with different chaimbers to set the tone, instead of a packing that heats up, bakes, and changes the sound over a few thousand miles. BUT, a CAI will change the exhaust tone, little deeper at idle, little louder at WOT. And even more if you add a header later...
Old Oct 8, 2006 | 08:46 PM
will adding a header and a down pipe lower the tone
Old Oct 8, 2006 | 08:51 PM
06cobaltls's Avatar
that stuff is a pretty nasty smell, i think it is the wrapping in the muffler as well, i get that when i installed a muffler on my eclipse
Old Oct 10, 2006 | 08:46 PM
06Pursuit's Avatar
by the way guys, that smell isn't stickers, its the paint on the exhaust. My pacesetter is painted, and i even added some antirust paint durring instalation. I smelt somethin commin from the car when i installed it. after a while the pipe where the flange for the cat is is starting to burn the paint. don't be alarmed. U can just throw another coat whenever u get her in the air!
Old Oct 10, 2006 | 09:47 PM
1SloBowtie's Avatar
No, these will make it more agressive, louder. More flow though the exhaust, more sound. If the sound is too loud for you, look into adding a resonator...
Old Oct 10, 2006 | 10:19 PM
Like what do you mean more agressive like more of a v6 sound or what, I just wish my pacesetter was deeper at wot.
Old Oct 10, 2006 | 10:21 PM
1SloBowtie's Avatar
It'll never sound like a 6. It'll just get louder...
Old Oct 10, 2006 | 10:27 PM
Very soon I will be ordering a Cobalt Addiction header and the xtm 2.5 downpipe with the high flow cat and I was wondering if I will through a cel (and I know that this has most likely been posted before but what hasent).
Old Oct 10, 2006 | 11:18 PM
EtyrnuSS's Avatar
Ok, pacesetter does use a channeled and fiberglass-filled muffler. It will change tone some after a week to a month. Little deeper at iddle, etc. The smell is the paint and the fiberglass baking. Had one on my neon, and it the smell went away after a week or 2.
