Quick L61 cam question
Old Feb 8, 2009 | 08:07 PM
USAF1123's Avatar
The L61 cams are compatable with the the LSJ cams but the LSJ cams run at different timing. Does this require a tune? Also, would the stock L61 valves and springs work with an LSJ cam, or would they also have to be from an LSJ? Also does anyone know what the performance gain of this swap is?
Old Feb 8, 2009 | 08:08 PM
MP Cobalt's Avatar
Yes, this will need a tune to run most likely. Why you going with a LSJ cam? Yes the valvetrain will withstand the LSJ cam
Old Feb 8, 2009 | 08:12 PM
USAF1123's Avatar
Just exploring the options.
Old Feb 8, 2009 | 08:14 PM
BLKLS's Avatar
if i remember right, the lsj and the l61 have the same profile, just different timing.
Old Feb 8, 2009 | 08:18 PM
MP Cobalt's Avatar
Well if you want to get a good gain. Go with the comp cams stage 1 and get it tuned or go stage 2 if you want but you will have to get a 2.4l manifold and tb
Old Feb 9, 2009 | 10:04 PM
XM15's Avatar
Same profile. You can get the adjustable cam gears though and play with the timing that way.
Old Feb 9, 2009 | 11:56 PM
HunterKiller89's Avatar
correct. im not positive, but i think both engines have the same valvetrain also with the exception of different valves
Old Feb 10, 2009 | 02:22 PM
massivematt's Avatar
go with stage 2 comp cams. Its the only way lol
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
patooyee
Oct 15, 2015 05:11 PM
ThoR294
Oct 4, 2015 08:44 PM
