ram air concept
Old Jun 23, 2007 | 01:15 AM
Jn2's Avatar
Jn2
ram air concept
as we all know there is a GMPP intake mod to make it so that the air goes into where the box go...im not saying my concept idea is better, or thats its good, just something i came up with when i was looking at some trans am, or here's what i got planned
use the bottom of the airbox from the stock 2.2 intake, put the filter on it, cut the shape on the center of the hood, mount the bottom of the box on the hodd, w/the filter on it, than route the piping to the throttle body using universal intake piping, and cut the MAF sensor adapter off of the top part of the box(using the airbox mod), connect all the piping and there u go i made a sorta cartonnish drawing for it on my comp...
now i was some of u might think of this problem too...how will u open ur hood, simple, when u do all this, the air box will no be connected to the hood, it will actually be compressed against the hood when u close it, so lining up the hole in the hood with the box will be the hard part...hard, but do-able...
ps-its just an idea i had, i'ma try it to see if it work or not....performance gains i expect is nothin more than i would with an intake, just thinking of doin it fo the hell of it....
Old Jun 23, 2007 | 01:20 AM
YelloEye's Avatar
The things people do at dark thirty.....
Good idea though, its similar to how the WRX intercooler is mounted.
Old Jun 23, 2007 | 01:26 AM
jgarciarivera's Avatar
That's right. Also it seems the GM modified cobalt has the same setup. Here's the link.
https://www.cobaltss.net/forums/show...ht=car+concept
Old Jun 23, 2007 | 02:22 AM
Jn2's Avatar
Jn2
yeah but mine will be centred on the hood, not offset, and i know thats what alot of people are looking for...so ima try it...
Old Jun 23, 2007 | 09:45 AM
YelloEye's Avatar
Let us know how that goes, cause I might end up doing this also.
Old Jun 23, 2007 | 10:27 AM
Trey6417's Avatar
I think i may go ahead and try it as well, I had this general idea myself but felt stupid cause it just didn't add up to me. If bringing in "forced air" passed the MAF, won't the computer control the amount of air coming in anyways? If not, wouldn't the forced air need more fuel added to make it actually work? Sort of like a turbo...without the turbo and no where near the amount of difference. Anyways, whenever I get a spare hood and a day off, i'll try it myself. But I'm looking foward to seeing how you overcome this. And if anybody can answer my question, i will listen. I'm no forced induction wiz, i just know what i've read up on back when i wanted to turbo my car.
Old Jun 23, 2007 | 01:18 PM
Jn2's Avatar
Jn2
a completely functional ram air producess less than 1psi, and thats on a LS1 going 80mph if i recall correctly...as for the air needing more fuel...i dont think i'll be adding that much air to where the stock settings cant adjust to it
Old Jun 23, 2007 | 01:25 PM
YSUsteven's Avatar
LewiSS has already done this.
https://www.cobaltss.net/forums/show...ighlight=scoop
He even dynoed it blocked and unblocked to see the performance gain.
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/gmpp-intake-dyno-numbers-47695/
no_ss
Oct 18, 2015 11:58 PM
z28addiction
Sep 28, 2015 12:03 AM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
