Red's K04 Turbo Build
Old 06-19-2012, 12:09 AM
  #351
Axelthered05's Avatar
what do you mean would not budge? just unbolt the nuts, you have two so use them as ancors to losen each other
Old 06-19-2012, 09:28 AM
  #352
2009CobaltLT's Avatar
Glad to see that TTR mani went to a good home build looks great
Old 06-19-2012, 10:00 AM
  #353
klutch814's Avatar
we got the nuts off..
Old 06-19-2012, 11:26 AM
  #354
dayhoff35's Avatar
awesome build
Old 06-21-2012, 09:01 AM
  #355
ok so taping the block for 3/8 NPT and doing threaded drain tube has fixed the oil leaking issue so no more leaks pics to come at a later date
Old 06-24-2012, 01:17 PM
  #356
klutch814's Avatar
do you have anypics of what bolts hold the wastegate on i think thats my problem..
Old 06-24-2012, 05:21 PM
  #357
the bolts that are used to mount the wastegate to the compressor have nothing to do with your boost pressure the only bolts that might efect your boost pressure are the ones on the waste gate rod
Old 06-25-2012, 08:47 PM
  #358
klutch814's Avatar
iom sure your tired of me..but do you have any pics of the wastegate rod?
Old 06-26-2012, 12:30 AM
  #359
waste gate rod is light blue
Old 06-26-2012, 10:35 AM
  #360
klutch814's Avatar
i cant tell from the pic is that nut on the end of the rod all the way down?
Old 06-26-2012, 09:37 PM
  #361
its tight against the waste gate arm
Old 06-26-2012, 09:53 PM
  #362
klutch814's Avatar
yea i know that but i meen is it as far down the rod as it can go?
Old 06-26-2012, 11:09 PM
  #363
nope only enough to hold the waste gate arm closed
Old 06-26-2012, 11:39 PM
  #364
klutch814's Avatar
heres a question.. maybe stupid.. do you build boost at idal like if you rev it/
Old 06-27-2012, 01:53 AM
  #365
nope only under load (when driving)
Old 06-28-2012, 02:58 PM
  #366
So today I blew a silicone coupler today split it right across the top, did some poking aound and pulled off the upper charge pipes and much to my iritation there is a lot oil in the charge pipes so im gunna go ahead and say that my previous fears of a bad turbo are true and seeing how i have no money right now to replace the silicone coupler let alone the turbo and no working car im gunna say its starting to look grim I will decide over the next few days what to do with it, my parents are starting to wory that its becoming a money pit. they pretty much already told me to "return it to working order" so we will see
Old 06-28-2012, 03:05 PM
  #367
Ouch...
Old 06-29-2012, 09:36 AM
  #368
klutch814's Avatar
damn man that sucks.. i blew one off the other night but the clamp wasnt tight. and by the way thank you for all your help. took me a half a day but full foost is right around 10 and average is 5 with the MBC off.. i may get the tru boost.. but thanks man. im sure i was a pain in the dick lol
Old 06-29-2012, 09:48 AM
  #369
nah its cool im glad you got it right though
Old 06-29-2012, 11:41 AM
  #370
ok so i have been promissing photos for a while now so here ya go
this is the tiny hole that resulted from drilling the block (pic is looking down the bolt hole. is now patched and pluged
started taping the block for 3/8npt you can still the clump of metal shavings that I had to clean off
3/8 npt fitting installed in the block
then we have some pics from this last weekends RKC car show yes I was the first non staff to get there
then we have the blown coupler
and the oil in the charge pipes and in the turbo aswell
Old 06-29-2012, 02:00 PM
  #371
Ok a new turbo is on the way along with replacement couplers, my parents are all like but they go on vacation on sunday so whatever it should be done before they get back
Old 07-04-2012, 11:03 AM
  #372
well I got the bumper off and the intercooler I was using has a huge dent it it of the back of it, most likley from the tow truck ramp from the incident with the oil cap so with the help of my uncle a new and significantly larger intercooler was ordered so I started to unbolt all the intercooler piping and gess what I found, more oil inside the pipes and the intercooler was flooded aswell
Old 07-04-2012, 11:14 AM
  #373
Looks like someone needs a catch can
Old 07-04-2012, 05:54 PM
  #374
I have an independant venting system for the crank and cylinder head that are not even conected to the intercooler or intake piping, this is all from the turbo thats leaking oil into the piping
Old 07-04-2012, 05:57 PM
  #375
le pic of venting system
Quick Reply: Red's K04 Turbo Build
