Rev limit question for all Ecotecs!
What's the highest I can rev with stock balance shafts and stock crank?I have forged pistons,eagle H beams,ARP head studs/rod bolts/ ZZP 82# valve springs and retainers.Stock cam.Just curious what it can handle with that hardware.
I'm a small blower 2.2L semi built and studded.Just seeing if the extra rpm will help keep me in 3rd through out the 1/4 mile instead of hitting 4th at the very end.And I'm also seeing if the higher rpm will keep me more in the powerband.I have a ported head as well.If not then I will shift earlier.Just a test until it hits the dyno
