running s/c without h/e hooked up
is it possible to run a supercharger with the endplate not connected to anything? i mean just to get the car running, not boosting or anything.
I personally wouldn't. I mean at that point it would only be full of air and air heats up faster then coolant. You would probably run incredibly hot. Just look for a used one on here or buy one from one of the vendors. OTTP sells a new one for under $200. Eaton's put off a lot of heat and I wouldn't want to risk running one without having a way to cool it down.
Yes. I did this till i got my pump wired and plumbing done.
Originally Posted by 08baltls
(Post 6635813)
You will be fine.
yeah i got it in the driveway now. afr's are so high that my gauge was just like fuck you. it said it on the display. weird.
You'll be fine
Gm warrenties the sc kit for the 2.2 cavy with no heat exchanger |
Originally Posted by ryman416
(Post 6635851)
oh i already have the plumbing and h/e with the pump all installed. im just waiting on a tank and some hose fittings to install tomorrow and was just seeing if moving it into the driveway was possible without going kaboom. The other issue is the fact that im running incredibly too lean (16-18!!!) so im def not gonna drive it anywhere.
(Post 6636084)
Oh ok. I thought you meant like just the manifold with a blower on top and nothing hooked into it at all. Haha. And yeah just moving it around a little would be fine. I just wouldn't plan on driving it anywhere til it's all hooked up and running.
That could be a long an arduous road. I've flashed the first and then two updated tunes and am still not running 100% right. And Wednesday will be two weeks since I initially started the tuning with Vince.
(Post 6636120)
Sucks you have to use trifecta
