SC or TC
Ok so im just about to start ordering my parts for a build im gonna be doing come spring, i live in Alberta and no garage :P. Anyway I just wanted an opinion on which to do/which is easier to install in your driveway ?
If u havent started buying parts for your build here's a guy selling his S/C kit
https://www.cobaltss.net/forums/part...thread-265372/
EDIT: Not to sure if he'll ship to canada, need to ask him
where in Alberta are you?
a local just got his wrecked SS/SC back - and if he buys another SS/SC with a blown motor ect, he would then have all the parts for you to convert to supercharged;
I don't know exactly what you would do though for ECM;
I have previously understood that the L61 cars use the same ECM as the LSJ ~ which makes this swap so easy...
but I've been wrong before
A cut out is basically a Y pipe right after you downpipe. 1 end goes to your cat back and 1 end is open for free flowing. Cruising = cut out closed and routed through the cat back. Racing = cut out open and routed to the open end.
ya i googled it since im up late also found this surfing as well, maybe you guys can tell me if its missing anything
Supercharging 2.2L
- Eaton m62/harrop tvs1320 supercharger
- LSJ intake manifold(m6x1.0 75mm x2)
- LSJ lower intake manifold bracket(m8x1.25 50mm bolts x2, m10x1.5 50mm bolt x1)
- LSJ alternator bracket(m8x1.25 130mm bolt x3)
- LSJ belt(stock pulley-3.0"pulley=stock belt, smaller than 3.0=stgII belt)
- LSJ belt tensioner
- LSJ idler pulley
- 42lbs/hr fuel injectors or more
- injector harness( repin to stock harness)
- LSJ air intake
- LSJ intake manifold gasket
- Lsj TB(repin/rewire required)
- m62 gasket
- extended upper radiator hose/LSJ upper hose(1.25" in/out)
- 10ft of 1.25" hose
- a lot of 1.25" worm clamps
- a few 1.25" tees and elbows
- heat exchanger(s)
- filler neck/overflow tank
- bosch intercooler pump(from lighting/cobalt/ion is fine)
- intercooler pump bracket(m8x1.25" 40mm bolts x2, m8x1.25" 55mm x2)
- 1gallon of dexcool
- 1step colder spark plugs
- wideband gauge
- boost gauge
- Tuning(Trifecta)
OPTIONAL/RECOMMENDED
- option B
- aftermarket air intake
- dual pass endplate
- full exhaust(1.75" primaries, 2.5" downpipe, 2.5" exhaust)
- some type of mount set up to help against wheel hop
- LSJ supercharger sensor(to plug hole on blower)
Supercharging 2.2L
- LSJ idler pulley
- LSJ air intake
- m62 gasket
- heat exchanger(s)
- wideband gauge
- boost gauge
- Tuning(Trifecta)
- option B
Blower install took me about 8 hours in the driveway the first time I did it. Besides having to go out once for some random zip ties and hose clamps. I bet I could blow it out faster now that I've done it once.
