Seafoam..
Old May 7, 2009 | 05:09 PM
xxxxsh4d0wxxxx's Avatar
Seafoam..
I poured 1/3 of the bottle down the TB with the car idling, turned it off for 5 minutes, turned it back on and no smoke really. There was a little bit of black smoke when I revved it higher into the RPM's, but that's it.
Is this normal?.. Should I even see white smoke when pouring it down the TB, I assume I would, or does this just mean my car is clean?
I have 12,000 miles on my Cobalt.
Edit: I have taken the brake booster line off and ran Seafoam through there also, no smoke, besides a few puffs of black smoke higher in the RPM range.
I've seen dudes Seafoam at 7,000 miles on a Cobalt and that **** smoked like no other.
Clean car much?
Old May 7, 2009 | 05:10 PM
umrdyldo's Avatar
Is this normal?
You don't need seafoam so early .
It's more of a 50k mile item.
Old May 7, 2009 | 05:11 PM
D4u2s0t's Avatar
Is this normal?
feed some through a vacuum source as well. that really gets it in there. but smoke is only g oing to come out if the engine is dirty. if it's not that dirty not much smoke will come out of it.
Old May 7, 2009 | 05:16 PM
05LSCobalt's Avatar
i got 42K on the my balt. you thik its about time for seafoam?
Old May 7, 2009 | 10:52 PM
Hence why the bottle says every 3,000-5,000 miles? It's more of a preventative/maintenance, item, in my opinion.
The only vacuum source I'm aware of, is the brake booster hose, which is impossible to get to. Am I even supposed to see smoke if I just pour it in the TB? I saw a hint of black smoke when I revved it up to like 6,000 RPM's, but that was it. Either I did it wrong, highly doubtful, or my car is clean.
I would.
Old May 9, 2009 | 10:14 AM
Bump.
Old May 9, 2009 | 10:16 AM
MaxVQ35DE's Avatar
it says use every 3 - 5 k for only one reason.... YOUR MONEY!
Old May 9, 2009 | 10:22 AM
Hypertension's Avatar
I'm told by a friend that whenever he uses seafoam it fouls his plugs. If I were using it as regular maintenance on basically oil change intervals that would be freaking expensive replacing fouled plugs all the time! I haven't used it myself so I cant say with certainty but I will be testing it out in the next 6 months or so. His smokes like hell when he uses seafoam but with only that few miles yours probably is just too clean to smoke much. I don't think you need to use it so often unless you just don't mind spending the $ and have everything you need.
Old May 9, 2009 | 07:23 PM
Blue_Balt's Avatar
x2
You don't need to do that till you're past 50k.
Old May 9, 2009 | 07:29 PM
stacy_dammit's Avatar
i did my seafoam at 53,xxx and very lil smoke
Old May 9, 2009 | 09:04 PM
Originally Posted by Blue_Balt
x2
Meh, to each his own, I suppose.
Old May 10, 2009 | 01:58 AM
tonio5555's Avatar
12k is early, but no smoke is a good sign
Old May 10, 2009 | 02:29 AM
kissmySS08's Avatar
i put about a 1/3 of a can in my brake booster line and mine blew smoke like a bitch for about 15 minutes.... mines an 08' TC with about 22,000 miles so i guess it all depends on the car cause i expected to see nothing on that new of a car?!
Old May 10, 2009 | 04:33 AM
halfj99's Avatar
i used this on my old alero and was driving down the road, my ol man went past me the other way, i get a phone call withing 3 seconds of him freaking out asking why my car was smoking so bad was pretty funny messing with him
Old May 10, 2009 | 04:42 AM
That's why I did it. I know some people with low mileage have gotten a ****-ton of smoke, so I just wanted to make sure.
Old May 10, 2009 | 05:41 PM
kissmySS08's Avatar
yeah thats what i figured... for like $7 bucks, why not lol
Old May 10, 2009 | 05:50 PM
blue05ss/sc's Avatar
dumb ass question....any negatives about sea foam
Old May 10, 2009 | 05:52 PM
Champ_'s Avatar
i seafoamed my probe gt with 245k on it. And dammm that thing made its own cloud....that **** was DIRTY!
Old May 10, 2009 | 06:07 PM
cobalt man's Avatar
what is the point of this ****? what do it do besides blow smoke?
Old May 10, 2009 | 06:11 PM
boostedss26's Avatar
^^ gets rid of carbon, cleans inectors and carbs, stabalizes fuel. I have never changed plugs after i sea foamed anything of mine never had an issue
Old May 10, 2009 | 11:26 PM
Nah, it's 100% safe as long as you follow the directions.
Same, but I've heard people say that it "fouled" their plugs; they must have done something wrong, or something, because I've never had this happen with any vehicles I've used Seafoam on.
