seafoam a 2.2? HELP!!!
Old 11-17-2008, 10:30 PM
djrik213's Avatar
can anybody help where do i is the vac hose or whatever? where do i put the seafoam in besides the gas and oil?! and yea i know my engine dirty?
Old 11-17-2008, 10:31 PM
boostedss26's Avatar
cant you pull the one to your valve cover to intake?
Old 11-17-2008, 10:32 PM
HackAbuse's Avatar
Powerwash that ****, jeeze.
Anyhow, use your brake booster hose. It connects to the bottom of the intake manifold, and the other end connects to the brake booster.
How many miles are on your car?
Old 11-17-2008, 10:34 PM
djrik213's Avatar
yea i know its dirty lol
40k
Old 11-17-2008, 10:35 PM
HackAbuse's Avatar
40k
Seafoam wont do you a whole lot with that little mileage.
Wont hurt though
Make sure you change your plugs right afterward.
Old 11-17-2008, 10:40 PM
djrik213's Avatar
i have to change my plugs? i heard u had to change the oil but i didnt know that!
Old 11-17-2008, 10:42 PM
HackAbuse's Avatar
You don't have to, but you definitely should
Old 11-17-2008, 10:43 PM
ive sea foamed all my vehicles and never changed plugs after
SS_Ry's Avatar
kinda like you should pay back beck the $150 you owe him
Old 11-17-2008, 10:45 PM
djrik213's Avatar
so can anybody point out where on the pics should i put it?
Old 11-17-2008, 10:48 PM
take the vaccume line off your brake booster or off the valve cover going to your intake.
Old 11-17-2008, 10:50 PM
HackAbuse's Avatar
Don't use the valve cover hose, that's not a vacuum hose.
Old 11-17-2008, 10:51 PM
djrik213's Avatar
so do it off the brake booster hose? and where is that located?
Old 11-17-2008, 10:54 PM
if it sucks air through the intake it will pull some seafoam
the big round black thingy that your brake fluid resivor is mounted on has a black hose on it that the hose off and put it in the bottle of seafoam when the engine is hot and running
Old 11-17-2008, 10:56 PM
HackAbuse's Avatar
the PCV hose doesn't suck very much at all, he needs to use a hose that's after the throttle body, which the only one is the brake booster.
The brake booster hose is on the right side of the intake manifold near the bottom. You can't miss it.
Follow it back to the brake booster and pull the end of the hose out of the booster. It won't be easy but you can do it. Keep in mind that the car will NOT idle well at all without the brake booster hose attached. Suck the seafoam thru that as per the instructions on the can.
When you're done just pop the booster hose back into the booster.
Old 11-17-2008, 10:59 PM
djrik213's Avatar
sry im a *******....but yea i know but can u tell me in the pic where it is? like is it in the right left or what
HackAbuse's Avatar
You can't see it in the picture.
Old 11-17-2008, 11:04 PM
djrik213's Avatar
is it that big clear thing on the right next to the fender? thats the brake resivor?
Old 11-17-2008, 11:05 PM
Moderator Alumni
Erod's Avatar
I love Seafoam
Old 11-17-2008, 11:07 PM
HackAbuse's Avatar
No, do you know what the intake manifold is?
Old 11-17-2008, 11:08 PM
Seafoam FTW
Old 11-17-2008, 11:22 PM
djrik213's Avatar
ya ok i just got the owners manual and i found the brake resivor was
is it easier to do it on an ss? and k there is a hose on the bottom of the intake is that the hose?
Old 11-17-2008, 11:31 PM
Maven's Avatar
In the second picture there is a rubber hose coming from the back of the manifold, it runs on top of and along the back of your oil filter, itll have plastic mesh on it in places, follow that line until you find where it connects on the other end, it will be attached to the brake booster, the black bowl looking deal that your brake fluid holder/master cylinder is bolted to. Disconnect it, and use that to slowly poor the seafoam into. OR, you could just get a spray bottle and spray it in through the throttle body, much easier, plus itll clean the throttle body
I dont recommend putting anything other than OIL(or leak detection dye) into your crankcase. No Seafoam in the oil for me thanks.
You dont HAVE to, you dont NEED to nor is it RECOMMENDED by the manufacturer(or any technician Ive ever worked with, myself included) to replace your plugs after performing a top engine cleaning.
Old 11-17-2008, 11:40 PM
boostaddict's Avatar
^^ listen to this guy. he is the king of ecotec knowledge
Old 11-17-2008, 11:45 PM
Maven's Avatar
Thanks, I am not the King, but I sure as **** sit at the grown-up table on Turkey Day.
Quick Reply: seafoam a 2.2? HELP!!!
