so i got what i deserved
Old Sep 17, 2009 | 04:32 PM
jonxxxedge1's Avatar
i went cheap and bought the ebay obx header and downpipe, and the flange is bent. too bad i dident know till after i put it on. at first i thought it was the gasket, so i took it off and changed that. still was leaking so i put the stock one. PITA!
not sure if it came like that, or if it happened when i put it on
if i get my money back, ill buy a zzp setup
Old Sep 17, 2009 | 04:34 PM
randizzle's Avatar
wow. that isn't just a little bit warped.
Old Sep 17, 2009 | 04:36 PM
and i only took the car for 2 15 minute drives
Old Sep 17, 2009 | 04:37 PM
Mindrot's Avatar
You didn't deserve that. You're just another Ebay victim. ZZP will treat you right
Old Sep 17, 2009 | 04:39 PM
yeah and catless on a megan catback is a big nono!
Old Sep 17, 2009 | 04:41 PM
glen229's Avatar
i had one, that prolly happend in shipping
Old Sep 17, 2009 | 05:43 PM
blackbolt89's Avatar
lol. i have corsa sport and a CATTED dp and my car sounds like a honder above 4k lol
Last edited by blackbolt89; Sep 17, 2009 at 05:43 PM. Reason: Automerged Doublepost
Old Sep 17, 2009 | 05:46 PM
Jn2's Avatar
Jn2
wow, just get it warrantied, i bought a obx a year or 2 ago, worked perfectly, not one problem, hell the local who has it now is still running it, going strong with no issues since it was installed
also did you follow the proper trq order for the exhaust nuts? there is a specific order to tighten them in to preven warpage
Old Sep 17, 2009 | 05:54 PM
Cigar Hero's Avatar
Looks like poor manufacturing to me. My guess is that theyn'd destress the welds or had it in a jig to tack it then fully welded it on a bench. poor workman ship. All though it most likley TIG'ed still stress builds up in the structure.
You might be able to fix it if you bolted down to a heavy steel flat bench to (like inch thick)
put a rose bub to it cherry red the slowly cool down with cold air, nor water, the shock might due more damage.
Last edited by Cigar Hero; Sep 17, 2009 at 05:54 PM. Reason: Automerged Doublepost
Old Sep 17, 2009 | 06:53 PM
Jn2's Avatar
Jn2
could be a manf flaw, although its the first i have seen from obx on the cobalt platform...everyone else seems to be ok with theirs
Old Sep 17, 2009 | 09:11 PM
Mike85220's Avatar
When I got my 4:2:1 header for my wife's 2003 Sunfire 2.2 Ecotec, I had to do A LOT of tweeking to it.
I first noticed the ports had slight difference in size thanks to weld blobs, and tube alignment.
-I dremilled these all to the same size and shape.
Then I noticed that the gaskets did not line up 100%.
-I had to dremil these gaskets to allow the bolts to go through and just as importantly not obstruct air flow. Some material was in the flow pathways! Not any more.
I then took the flange and placed it on my dining room table and notice a slight rocking.
I knew it was warpage.
So I then took it outside to place it on a flat object against the flange and look at the sun.
I could see a little light peering through. It was upsetting, but I knew I could get the flange flat.
-I found the areas that were the problem and ground them down.
-Then I took heavy grit sandpaper and rubbed the flange back and forth on the concrete until there was no more rocking.
-I than used finer grit paper to get the rougness out.
-The drill with a brass attachement was then used.
-I finally went through it all with a honing tip.
After this, no more rocking, it was flat to all flat surfaces and all the gaskets fit and line up with the bolts. All ports match too. All burrs and excess weld blobs are gone.
I knew when I got this off E-bay that it was going to be a project and not a slap it on out of the box.
The good thing is, I didn't spend $350+ on it and was willing to use some elbow grease.
Old Sep 17, 2009 | 09:38 PM
YSUsteven's Avatar
Yeah, they probably dropped a truck on it during shipping...
Thats a manufactoring defect.
Old Sep 17, 2009 | 09:40 PM
glen229's Avatar
dont laugh, youd be supprised, it happend when i shipped mine also why i said that, so HA, lol jk
Old Sep 17, 2009 | 10:36 PM
Jn2's Avatar
Jn2
The one 1 ordered was straight bolt on out the box...perfect welds and fitment
Old Sep 17, 2009 | 11:01 PM
Mike85220's Avatar
The problem is, you got a shop with several people working there and some do good and some don't.
There is also the factor that E-bay sells a lot of no name, or rip-off model headers so who knows half the time if it is a clone or the real deal. Well, I guess if it the real deal, it actually fits out of the box, lol.
Mine needed help, but the price reflected this.
Old Sep 17, 2009 | 11:02 PM
slowswap's Avatar
Cheap ass.
Old Sep 17, 2009 | 11:13 PM
Originally Posted by slowswap
Cheap ass.
i cant afford a 800 dollar vibrant setup being a student with a part time job
where about depew do u live slowswap? im also in depew
Old Sep 18, 2009 | 02:13 AM
xxxxsh4d0wxxxx's Avatar
ZZP man..
It's not that much more expensive, and it's quality.
**** E-Bay.
Old Sep 18, 2009 | 05:35 AM
87GPLE's Avatar
Can you return it or exchange it? If it was me, I'd get a torch heat that bitch up and pound it with a hammer. But that's just me
Old Sep 18, 2009 | 05:40 AM
utsadude's Avatar
Originally Posted by xxxxsh4d0wxxxx
ZZP man..
**** E-Bay.
Idk man...
I bought my OBX header off of a guy that decided to upgrade to ZZP, and a week later when I was talking to him the subject of the headers came up and he said he hated the new one he had.
Oh well, I've heard mixed reviews.
Old Sep 19, 2009 | 07:44 AM
slowswap's Avatar
Off of George Urban by Transit. Save for good parts man. I've worked on a lot of the fast Cobalt's in this area and you're best off saving and not skipping on cheap parts.
Old Sep 19, 2009 | 07:48 AM
hmm u must live like seconds away from me, i live off olmstead
yeah i learned my lesson
riceburner
Sep 30, 2015 03:54 PM
JMH
Jan 18, 2007 05:14 PM
NGalaxyTimmyo
Feb 9, 2006 11:26 AM
JonyyB
May 9, 2005 09:26 AM
