Spanky's 2.2 Turbo Build....Stage 2
Old 10-21-2010, 07:26 PM
  #201
Spanky's Monkey's Avatar
so i got that spring in today will post pics as soon as my host stops acting stupid.
Old 10-22-2010, 08:46 AM
  #202
zzp brfps install. it really does take like 10mins. they say 5min but quick release clips aren't always quick.
i need a vacuum distribution box.
install my 10psi spring setup in the tial mv-s 38mm.
Old 10-22-2010, 11:02 AM
  #203
stenguyen1's Avatar
what does the zzp brfps do?
Old 10-22-2010, 11:35 AM
  #204
raises fuel pressure with boost pressure 1:1 past 12psi
Old 10-22-2010, 11:36 AM
  #205
mkriebs's Avatar
BRFP stands for boost reference fuel pressure.
Old 10-22-2010, 11:39 AM
  #206
stenguyen1's Avatar
o ok cool. thanks man. how much did you pay for it? retail like it says on the site
Old 10-22-2010, 11:44 AM
  #207
got it off glen for a far better price then zzp
Old 10-22-2010, 01:41 PM
  #208
stenguyen1's Avatar
ahhh man you lucky lol
Old 10-22-2010, 02:12 PM
  #209
Tundraboarder666's Avatar
And this is necessary because?
Old 10-22-2010, 02:16 PM
  #210
i'm just getting started here. meth, more boost and a trans are in my future.
Old 10-22-2010, 02:24 PM
  #211
Mr.N00bLaR's Avatar
Cobalt & Ion ---> ZZ Performance
Originally Posted by ZZP
So how and why does this kit work? What is it actually doing?
The PCM doesn't compensate for boost over 17.5psi (12psi on LE5), so the car goes lean after that. This is unless you raise fuel pressure the same amount as boost. You can try and tune around this but it's guess work and a poor solution.
What we did is leave the factory regulator in place then the PCM works just like stock and all the tuning is stock (or whatever your PCM is). Then we added an adjustable regulator in the rear of the car. Because the factory regulator is still in place (using install option 1) and keeps it at 60, the car operates just like our regulator was invisible. Then when boost hits about 17psi, our regulator is at 60psi matching the stock one. Again ours isn't doing really anything but when the boost passes 17psi, ours go up with boost. So at 18psi ours adds say 1 psi of fuel pressure.
Fuel flows based on pressure differential. So if you have 60psi of FP and 17psi of boost, the injector only flows like as if it's running at 43 psi. The PCM normally compensates for this but stops at 17.5 because the tables don't go any higher. So if you run 18.5psi of boost, the PCM is fueling the car as if you have 17.5psi of boost or 42.5lbs of pressure. When you go past that the PCM still fuels as if the injectors are at 42.5lbs of pressure differential but they aren't. The more boost you run past 17.5, the farther off your fueling.
On the 2.4 liter kit, we adjust the regulator to kick in at 12psi instead of 17, but the function is still the same.
Our kit makes pressure rise 1:1 past 17.5 and therefore requires no tuning. Optionally, we use the stock EVAP line to send boost/vac to the additional regulator in the rear so there is no line to run but you have to disable EVAP codes in the PCM. If you run new line, EVAP stays stock.
Old 10-22-2010, 02:42 PM
  #212
Haha yeah I just read that on the ZZP website...
IDK I guess let me know how it works and if it's really worth 200 ******* dollars...
I'd rather let Vince try and tune through it. I will be going to 25 PSI as soon as I have a built tranny..
Old 10-22-2010, 03:01 PM
  #213
mkriebs's Avatar
$200... psh. Just be resourceful, for instance, using one of these would be alot cheaper. These are really archaic pieces, and very simple things. No reason to pay out the ass for one.
MSD Ignition - 2222 - Adjustable Fuel Pressure Regulator w/Boost Reference - Team C Performance
Old 10-22-2010, 03:02 PM
  #214
BlackCobalt707's Avatar
25 psi must be nice
Old 10-22-2010, 03:50 PM
  #215
that is a nice piece. glad i didn't pay full price, lol.
Old 10-22-2010, 04:22 PM
  #216
huckernage's Avatar
you can push it
Cavalier Turbo Drag Pont-Rouge Mai 2010 - 11.31, 124mph - Car Videos on StreetFire
Old 10-22-2010, 11:10 PM
  #217
Sick cavalier!
Ill probably end up going with that MSD piece than the $200 ZZP...
We will see what happens
Old 10-22-2010, 11:11 PM
  #218
mkriebs's Avatar
Yeah, that MSD piece seems to be a good deal. I found some other ones for cheaper, but they were no name brands, from England.
Old 10-22-2010, 11:17 PM
  #219
England is awesome. I once tag teamed a Lotus Elise with a friend in England... We were really drunk lol
Old 10-22-2010, 11:18 PM
  #220
mkriebs's Avatar
Lol.
Old 10-23-2010, 12:12 AM
  #221
getting spark blow-out at 8psi with a .035 gap. will a .030 gap fix this?
Old 10-23-2010, 12:15 AM
  #222
mkriebs's Avatar
Try .028, new plugs, or a step colder. If you are on stock plugs, DEF colder. Prolly even 2 steps colder.
Old 10-23-2010, 12:16 AM
  #223
already running 2 step colder and i'll try that as soon as the wife gets home. got her logging miles on the engine. i love a chick that is scared to get into it. totally respects my ride.
Old 10-23-2010, 12:18 AM
  #224
mkriebs's Avatar
Lol, hell yeah! Dang, if you're still getting blowout at .028 on 2 steps colder, I would start looking at the coils and ****. That would mean there is either not enough spark, or something else. Too much fuel could do it, what is your afr?
Old 10-23-2010, 12:23 AM
  #225
idle 14.7 give or take, tip in runs rich into the 12's and leans out to stoich. under boost at partial throttle it runs around stoich but leans out when the spark blow-out hits.
Quick Reply: Spanky's 2.2 Turbo Build....Stage 2
