Starter HELP
Old Jan 5, 2009 | 01:17 AM
slowbalt19's Avatar
Exclamation Starter HELP
hey guys i pulled my starter as it wasnt cranking the car. I hooked it up to the batt and it pushed out the pinion with the gear on it but it didnt rotate the shaft at all. Is my starter bad? also can autozone test it as well?
Old Jan 5, 2009 | 01:31 AM
Sw4y1313's Avatar
I tried having autozone/napa/schucks test my alternator last month, and they couldnt because they said the car was to new. Now im sure they could test the starter quite a bit easier but i wouldnt count on it. If you are putting power to the starter and the gear is not rotating, then its most likely bad. Take your car to the dealer and have them replace the starter under warranty. Or at least try.
Old Jan 5, 2009 | 11:03 AM
hugemurph4's Avatar
the only way really to test it is to take it out of you car and take it to autozone...obviously in a differant car... cuz they can test it there. its really easy to take it out all u need is to jack up the front end of the car.
Old Jan 5, 2009 | 11:44 AM
07cobaltguy's Avatar
its two wires and two bolts.
It is however a dealer only part or gmpartsdirect.com. I just went through this last week because i had a freak incident with a power wire shorting out. I went to a junk yard and got one for 60 bucks, but if you want a new one look to be paying about $287 with shipping and core charge.
Old Jan 5, 2009 | 03:24 PM
slowbalt19's Avatar
autozone said it was good, but when i put it in it didnt engage the flywheel, the crank turns fine and i didnt see any teeth missing. Any ideas?
bump for help
Old Jan 6, 2009 | 07:39 PM
Maven's Avatar
if you try to spin the pinion gear by hand (either way) what happens?
Gugi96
Sep 15, 2015 12:24 AM
juandirtymessican
Oct 27, 2012 10:41 PM
loudog3114
Mar 28, 2007 07:45 PM
lnadeau
Dec 15, 2006 06:20 PM
5150studios
Sep 5, 2006 01:04 AM
