Supercharger Build!
Old 02-12-2012, 05:18 PM
  #126
c1_c1rca's Avatar
i believe my bolts i used were actually m6x1.00x80, they didnt have tghe right size for me but these work, or it might have been m6x1.00x70, i cant remember
Old 02-12-2012, 05:22 PM
  #127
heathkidder's Avatar
yea true value had either 70 or 80 not 75 but i managed to the the other 5 intake mani bolts that were m6x1.00x25 from them but another guy said he installed it without the 2 bolts so im gonna wait till the install and prolly just buy both sizes lol
Old 02-12-2012, 05:40 PM
  #128
c1_c1rca's Avatar
thats what i did then used the ones that fit best, but your going to need a washer for those bolts to cause the head is to small and will fit into the intake mani, i believe i used one washer on the passenger side and 2 on the driver side cause of the oblong hole... but they have been working perfectly for me
Old 02-12-2012, 06:15 PM
  #129
Ill have to wait and see once i get it takin off
Old 02-12-2012, 09:19 PM
  #130
when i install the dual pass what cores do i need to switch the bottom two?
Old 02-12-2012, 09:30 PM
  #131
1LowLS's Avatar
the inner 2 will be "in" and the outer 2 are "out" so the top 2 need to be flipped.Be very careful.They are extremely fragile
Old 02-12-2012, 09:32 PM
  #132
IonNinja's Avatar
yes
per ZZP instructions:
http://s3.amazonaws.com/zzpstorage/i...structions.pdf
Old 02-12-2012, 09:34 PM
  #133
i seen a how to and it was the bottom two? so its the top two?
Old 02-12-2012, 09:39 PM
  #134
nvm it works either way thanks for the how to
  #135
1LowLS's Avatar
no no your right it is the bottom 2.Im thinking about it backwards lol my bad
Old 02-12-2012, 09:41 PM
  #136
ok doesnt look to hard just gotta be careful with the cores is all. im still tryin to hunt down those two damn bolts lol
Old 02-12-2012, 09:46 PM
  #137
1LowLS's Avatar
get 80mm if you have to and use some washers.
Old 02-12-2012, 09:47 PM
  #138
what two bolts are they talking about thats under the intake mani do you know those sizes? here is a pic
Old 02-12-2012, 09:53 PM
  #139
M10 X 1.50 x 50
i think thats the size for the bolt that goes where the green arrow is but they had mentioned another bolt under the mani do you know which there talkin about
Old 02-12-2012, 09:55 PM
  #140
GSDIESEL300's Avatar
Lol That was a fun one to put in once the intake mani is on.
Old 02-12-2012, 09:56 PM
  #141
do you know if the size i posted above is correct and what other bolt they may be talking about that is under the intake mani?
Old 02-12-2012, 10:02 PM
  #142
the way there how to shows there are only 5 bolts on top and 2 nuts and one bolt underneath? is this correct ?
Old 02-12-2012, 10:18 PM
  #143
I don't remember the size, it just came with my kit. I remember that one bolt in the location from the picture there was also a bushing to make the bolt fit inside there. I'm not sure on the nuts, there may have been one to hold that bolt in but I'm not entirely sure.
Old 02-12-2012, 10:30 PM
  #144
ok i guess ill have to wait till i start putting it in cause just talking about it and not seeing it isnt helping.
Old 02-12-2012, 10:39 PM
  #145
Yea, you can talk about all you want but when you start working on it you'll run into new problems you weren't prepared for. But it's worth it in the end.
Old 02-12-2012, 11:12 PM
  #146
1LowLS's Avatar
the 2 studs you see in your pic you posted,we dont have,so thats what the 2 longer M6 bolts are for
Old 02-12-2012, 11:53 PM
  #147
bluebalt07's Avatar
I didn't even put that bottom bolt on my intake mani. Honestly I forgot all about it til everything was already together and running and I haven't had any problems with it
Old 02-12-2012, 11:54 PM
  #148
well since its such a pain i might just skip it as well lol and since all the confusin about which bolts to get is over with i just need gauges and spark plugs and im done.
Old 02-14-2012, 02:33 AM
  #149
brand new ic pump and 6 pin to 8 pin tb harness
Old 02-14-2012, 03:25 AM
  #150
kingg5's Avatar
this is a bad idea...that bolt is there for a reason...
also, that bolt isnt that hard to get in. jay did it in like 15 seconds on his car. as long as your not a total simpleton you can do it.
Quick Reply: Supercharger Build!
