takin her in for the recall... what about an intake?
so i got the letter in the mail the other day about my fuel injectors being bad... im takin her in to get them swapped.... is it possible for me to order a GMPP intake from them, and do the work myself... will it void warrenty if i do it, or do i need them to do it since i ordered it through them?
I wouldn't order it from them...will probably charge you an arm and leg for it. Search around online to find a better deal. They won't void the warranty esp since its a GM product, unless you put it on wrong and something does happen due to that fact.
Check out www.crateenginedepot.com
yea....i got one too....btu im waiting till i get some feedback on here....i saw something about emissions in the letter.....i dont wanna get downgraded injectors.....that would blow
The recall replaces the factory injectors because of the likelyhood of a crack developing on the upper end of the injector near the fuel rail. The injectors are not downgraded just redesigned to eliminate the chance of a dangerous fuel leak.
I'm scheduled for Wed AM. I'll take a look at the replacement injectors to see what the difference is.
Chances are that is what will happen in most cases -- an "enlightened" mechanic doesn't go ape over aftermarket equipment. The service manual requires a check for aftermarket equipment before starting to diagnose a problem and it's when you run into a mechanic/service manager that takes this to mean ANY aftermarket equipment, whether it affects the car's problem or not, that you probably run into conflicts.
If you ever run into a situation like this just stay calm and ask them to put it in writing. Then work the problem through the manager and then the regional office. Documentation is the key!
That is all I know as of right now, the side airbag deal was for 05 2.2 coupes, and the injector recall was for 06's and higher I think, Im not too sure on that one seeing as I have an 05 ha, but I havent gotten a letter about the airbag one yet, and I wear my seatbelt all the time, and they said the improvement would only benefit those not wearing their seatbelts in the case of contact or an accident, iono but i think both recall articles are floating around here somewhere
Aftermarket parts dont void the warranty unless like FuzzMan stated GM can prove that the aftermarket part caused damage to another part. As far as the fuel injector recall there was a thread started back at the end of Jan. I actually called the dealership as soon as i got wind of it to see if i qualified for the recall and scheduled an appointment. I actually got the car in and taken care for about a week before I ever got a letter.
Lady at work dropped hers off at the local dealer. Took them 2 days to get to her car. I was like holy hell, just to pull the fuel rail and put new injectors on... i could of done that in like an hour or two.
Just got the new injectors installed. It took about an hour from turn-in to pick-up. As expected, I can't tell any difference in performance.
NOW I smell gas
-- Should go away after some driving....
Your's probably already has the new PN 89060563 injectors. I think this recall was for 05-06 2.2Ls. You'll get a letter if your car is affected.
NOW I smell gas
OrangeCoba
Sep 25, 2015 06:06 PM
