These are supposed to be like this right?
Car wouldn't run and made some awful noises so we pulled the head and looked this
then this
then saw these
and now this beacause.........................
Streetcar
Timing came 2 teeth off on the intake side and bent every intake valve.Got a donor head and robbed the valves out,Lapped them in to get em seated.Compression tested everything after.180 across the board
.Thanks to EvoFire and Tundraboarder666(his car)Was Work but we got it done in 2 days.Good times.
then this
then saw these
Streetcar
kinda off topic but i have the same turbo kit. what heater core line did u tap into for ur turbo coolant tee? I tapped into the heater core line going to the thermostat. I couldnt manage to use the other line bc of how it is bent/made.
Is this the same line u tapped into? hard to see in the pic.
ya mine has been hooked up for 3 yrs and i have had weird over heat issues with my car. only when it is cold out side will my car start to over heat but if it is hot as hell out i never overheat.
I think its bc of the hot coolant being dumped back into the thermostat housing but i have no idea. I learned to deal with it. I dont drive my car in winter anyways so I try to avoid driving it on really cool days if all possible
thats really weird.We ahve no issues like that at all.you have the return going to the small bleeder hose that goes to the top of the surge tank?Maybe try switching heater hose as well?hmmmm
yep everything was hooked up correctly. after so many yrs of not figuring it out, i narrowed it down to 2 causes that i think it can be.
1.) air pocket in the system somwhere but after so long it should have worked its way out. (my coolant level is accurate when car is cold and hot)
2.) the return line for turbo coolant needs to be relocated and it could have eff'd up my thermostat.
Honestly i have ran it this long and not one problem (knock on wood) I dont think i am changing a thing. it is a pita to get back there. I know u know lol
Jumped teeth when we turned boost to 55 psi and rev'd to 9500rpm.......jk
78lbs valve spring install.When assembled,intake was 1 tooth off and we "corrected" it the wrong way,meaning it was 1 tooth retarded and we thought it was advanced.bad assumption.You know what they say,you know what happens when you assume,you bend valves
Most def.I would leave it as well.Maybe get a aftermarket temp gauge to make sure it's a false reading or not.just put the sensor in a different location
As stated.we thought it was a tooth advanced.had it backwards so when we "corrected" it.It was 2 teeth retarded.Luckily echaust cam was spot on so only had to replace the intake valves.Just a brain fart on our part but we got her running last night.Started 1st try and runs like a champ
XStylus
Forced Induction
Sep 16, 2015 06:19 AM
