? for thoes who have been tuned
Well seeing my build thread didn't take off and its all of 3 posts long and way down the page ill just post like normal lol..... for thoes of you that have been tuned you tell vince your mods but what else "special" have you asked for? Like rear o2 sensor disable? Speed limiter lifted? Thoes kinda things. Also anything I. Should know about this tune?
rev limiter upped? i dont know what other "special" things can be done but what you and i listed. but the tuning process is simple. i can try and assist you with it
ooh thats what your talkin about. i thought you meant it was $16,000 for them...and to answer your question. i dont know **** about them lol. i read about them a little but didnt pay much attention
They don't spin at 16k, they were just using it as an example.
Say at 8000 rpms you were making 250 hp, but because you don't have balanced shafts you could lose 8 hr, then at 4000 rpms you would only lose 4, if you were to make 16000 you could lose 16.
IMO wouldn't do it unless you had cam's and valvtrain already.
if that's your mods get headers and downpipe. That will get you the best gain for your build right now. if your sticking with N/A 1 5/8 primaries into 2.5 collector and downpipe. If you have any questions about N/A builds you can ask me or any other vets on here.
I wire the ic pump up myself so he won't control that. Why fans on with start? And I don't use my ac often so that's not a big deal. I just don't know what will benifit me or what to even ask for
"special" things i got were
-Fan high setting on @194*
-rear o2 delete(comepletly, the o2 bung in the DP is plugged)
-"numb'd" up the knock sensor so it would stop pulling timing from false knock
that should be it, everything else is normal, 7k rev limitor...i know he was working on a launch control and no lift shift for the non LNF's...reckless has the tune that has them on it...he's a 07 2.2
I wish it was hot as hell here lol... so far I told him no speed limiter, raise rev limit, rear o2 delete (for my wideband) then I made this post... can u explain more about this knock sensor? And no lift **** would be cool.... launch control for sure... ill have to ask him about that. Even tho he hasn't replied to my emails in 2 or 3 days and won't answer the fing phone! My friend is willing to buy a cable and or be a vendor and the guy won't return contact??? Def not the best at customer service I see
my knock sensor issue is not one that everyone would have, i was getting false knock from something that was hitting on the outside of the engine, not from real knock, so it was pulling timing thinking it was rod knock...
Uhh, you don't put the wideband in the rear o2 sensor (after the cat). The wideband must go before the cat or you will get false readings.
While Vince is an intelligent man, he certainly doesn't get back to you in a reasonable amount of time.
damn.... so now what do i do? cuz i told him to disable the rear o2.... ummm great also gene im gunnna pm you... i read all 30somethin pages of your build and it was amazing i still have a few questions! so i dont put the wide band in the manifold o2 bung right?
