timing chain hell
Old Sep 20, 2010 | 08:29 PM
BlackCobalt707's Avatar
timing chain hell
alright, heres the issue. after takin the head off the car im retiming the car to make sure its in good working order. well when i got the timing marks all lined up and the chain on, the damn thing jumps when i cranked the engine by hand. according to the chilton manual it says my tensioner is good. the chain only has 4-5k miles on it so it couldnt possibly be bad. the tensioner im not sure about, it was fine when i took the head off. i currently have it lined up again i just havent cranked the engine yet. any help would be greatly appreciated, thanks
Old Sep 20, 2010 | 08:45 PM
2007maroong5's Avatar
Is it possible one of the teeth on the gears got bent somehow? Even just a little could throw the chain. Use a straightedge to make sure both gears line up perfectly, you know in case one got tweaked. Anyways good luck.
Old Sep 20, 2010 | 08:54 PM
importtuner88's Avatar
I have not taken it a part but is the timing chain tensioner oil driven. If so when you crank the engine over, the proper amount of tension is not applied to chain causing slack in the chain, which then results in the chain skipping teeth on the cam gears.
Old Sep 20, 2010 | 08:55 PM
thats what me and my friend are talkin about right now. but yea, its oil pressurized. we was just thinkin about takin out the tensioner and puttin out in it and seein if that works
naw the teeth are all fine
Last edited by BlackCobalt707; Sep 20, 2010 at 08:56 PM. Reason: Automerged Doublepost
Old Sep 20, 2010 | 09:03 PM
Bl4des's Avatar
have you ever replaced you tensioner to the new style or do you still have the original in it
that just might be the problem
Old Sep 20, 2010 | 09:33 PM
theres a new style? i was using the same tensioner that came with the car
Old Sep 21, 2010 | 05:20 PM
when doing a timing chain, is the chain supposed to be tight when you turn the crankshaft either way? when i turn the crank backwards it kinda slacks up. but if i go forwards it has less. i know i got a shitty tensioner and got a new one on order but im just curious
Old Sep 21, 2010 | 10:20 PM
joshc.'s Avatar
it should slacken up a little bit but not a large amount.
Old Sep 21, 2010 | 11:31 PM
alright, well its not like alot of slack but its enough to have concerned me. new tensioner shows up thursday so hopefully the issue is fixed
Old Sep 23, 2010 | 08:50 PM
montecarloman's Avatar
When you install the tensioner you have to activate it by forcing the chain shoe towards the tensioner assembly itself. That will release the internal catch and allow the spring internal to the tensioner to pre-load the chain assembly.
Old Sep 23, 2010 | 09:29 PM
oooh, got ya. i couldnt figure out how to make it come out so i just extended it and screwed it in lol
Old Sep 23, 2010 | 11:12 PM
she should be back up and running tomorrow. i gotta get the new bolt, my oil feed should be in, and fill it up with oil and coolant and she should be boostin again
Old Oct 3, 2010 | 01:31 PM
alright well i still got a problem with this car. i got a new head gasket and tensioner and i retimed the car but the car still sounds like it has a little hesitation. i accidently broke a piece of my purge solenoid that is connected to the valve cover and i bored out the hole and stuck in a vacuum fitting and rtv'd it (ghetto rigged lol) but my vacuum is still low. any ideas what could be causing this? im bout fed up wit this car. nothin goes right with it
Old Oct 6, 2010 | 09:00 PM
Define "low vacuum" and what are you compairing the reading against? With all the modifications you've made it may be normal.
Old Oct 12, 2010 | 09:30 AM
when i say low vacuum im talkin 15-16...when normal before i took the head off was 18-19.
Old Oct 12, 2010 | 11:45 PM
Novajoe's Avatar
Is it idling higher than normal as well? If so it's a vaccum leak and you'll have to search for it. Since you just got done tearing the whole thing apart, It could be just about anywhere and you'll have to start elimenating things.
That vaccum fitting may still be leaking. I would check that first then if it's good, check other things like your gaskets on your intake/TB side and make sure none of them are leaking.
Usually you can spray them with something like soapy water and watch to see if it sucks it through.
Old Oct 12, 2010 | 11:47 PM
naw, idle is normal. i talked with a mechanic friend at work and he said hes most certain sure my timing is off and that off timing can cause low vacuum cause the valves arent opening when theyre supposed to at the right time. so ima spend another 4 hours of my life retiming the car...hopefully it works
Old Oct 12, 2010 | 11:59 PM
Novajoe's Avatar
yea sounds like that's deffinitely your problem. Chances are when you put the chain on it was one notch off or something along those lines. Just make sure that everything still lines up once you get your chain back on and put tension to it. I'll usually spin the crank 360 once or twice and then makes sure everything is still in line before I call it a day with the chain.
Old Oct 13, 2010 | 12:26 AM
Spinning the engine over by hand once or twice wont line up the marks. I don't know how many revs it would take to get it all lined up but the last one I put a head on I did I tried that. Ended up having to re-time it by taking the front cover off. I would recommend leaving the cover off when you time it up and set the tensioner. That way if it does jump you'll be able to see it. Also don't forget the cam bolts are torque to yield. After one tightening they are garbage so finger tight until you know you got it right.
Old Oct 13, 2010 | 12:28 AM
lol i think im on my 6th use of my cam gear bolts
Old Oct 13, 2010 | 12:33 AM
Novajoe's Avatar
I'm not going to tell you to re-use them just because you're not really supposed to, but I can't remember the last time I actually replaced cam/head/crank bolts outside of professional work. Never had a problem.
Old Oct 13, 2010 | 12:36 AM
same here, never had a problem wit them before, but head bolts, id always replace
Old Oct 14, 2010 | 01:48 PM
well for anyone who cars i retimed the car and switched the cam gears around just for ***** and giggles, i havent put it back together yet cause i dont feel like it right now but i might tonight after work. i hope it works
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
