Top Speed Limiter
Old Dec 21, 2007 | 02:41 PM
SpeedJunkies07LS's Avatar
Top Speed Limiter
ok heres the deal i have an 07 ls and it stops and tops out at 112 because of the top speed limiter heres the money question! How do iI get Rid of it???
any help??
thanks
mike greenhawk
Old Dec 21, 2007 | 02:49 PM
madmark's Avatar
find the wheel speed sensor wire that goes to the pcm. put a switch on the wire leading into the car. when you get to 110 flick the switch off and there ytou go
Old Dec 21, 2007 | 02:53 PM
YelloEye's Avatar
Or find someone with HPTuners, it is my understanding that it can be removed with it.
Old Dec 21, 2007 | 02:58 PM
JohnnySasakiMGS's Avatar
If you want to go faster than that you may want to get tires with a higher speed rating. I don't know what current tires you have on there but I would seriously reccomend NOT trying to remove the speed limiter. How long does it take you to get up to 112?
Old Dec 21, 2007 | 03:04 PM
saunders1986's Avatar
i had a 2.2 4 door rental, took me about 4 days to get to that speed.
Old Dec 21, 2007 | 03:07 PM
Old Dec 21, 2007 | 03:17 PM
montecarloman's Avatar
The motor just doesnt make the power in the upper range to push the car past 100 in 4th gear. Shift to 5th and mat the gas. JohnnySasakiMGS is right though if you dont have the tires DO NOT attempt those kind of speeds. A tire blowen out at a buck 20 will have an extreamly negitive affect on you health.
OrngBalt's Avatar
yea.. i wouldn't be doing this
not on a 2.2 it cant
Old Dec 21, 2007 | 03:21 PM
YellowLT's Avatar
Fast you can set it too is 120. But check your tires cause they probably arent rated high enough
Old Dec 21, 2007 | 03:23 PM
D4u2s0t's Avatar
you can remove the speed limiter and change shift points on an auto tranny with hp tuners on a 2.2. waste of money if you ask me because you can't tune anything else with it. not worth hundreds of dollars to change your governor. on my 2.2 i had the car up to 115 or so, and there was just nowhere else for it to go. took a helluva long time to get there too. how high are you going to get the car, MAYBE 120 for a nicely modded 2.2. so an extra 12 mph, and an extra 3 miles to get there.
Old Dec 21, 2007 | 03:28 PM
suburbanrobot's Avatar
I like to use that time for knitting a sweater
Old Dec 21, 2007 | 03:29 PM
D4u2s0t's Avatar
haha, yea. the car did feel damn stable at that speed though. i was never nervous or felt like i wasn't in complete control.
Old Dec 21, 2007 | 04:22 PM
Sw4y1313's Avatar
Can we make one of these threads a sticky. i swear they show up at least once a week. If your car isnt making the power to get to the limiter in a quarter mile, dont worry about it.
Old Dec 21, 2007 | 04:29 PM
Co|3aLt $$'s Avatar
wow....have a mullet do we?
Old Dec 21, 2007 | 04:31 PM
D4u2s0t's Avatar
what does that comment have to do with having a mullet?
Old Dec 21, 2007 | 04:32 PM
Co|3aLt $$'s Avatar
that's such a muscle car thing to say. "if you can't hit your governor in a 1/4 mile don't worry about it? I dunno, it was just a joke tho.
Old Dec 21, 2007 | 06:00 PM
Helltime's Avatar
WTF, the 2.2 isnt that flippin slow. Well, stock and with an auto it is but mine will haul to 110 (just did yesterday before i let off) in 4th gear no problem. It has the power you just have to free up the exhaust first, the dp and exhaust mani on the stock 2.2 is the killer if you ask me.
Old Dec 21, 2007 | 07:51 PM
tonio5555's Avatar
Is this true? How did I not know this? I mean a tranny tune on a 2.2 isn't worth much on its own, but I never knew I could tune my trans. how exactly does this work? Once my friend hooked my car up to HPT and he was able to log it but we didn't try anything else.
Old Dec 21, 2007 | 08:47 PM
D4u2s0t's Avatar
as far as i know you can't do anything except change the shift points. pretty sure it's been known for a long time, but the reason why no one does it is because what's the point really. you can't adjust anything else, and just raising the shift points isn't going to do anything. so why spend 500 dollars for it.
Old Dec 21, 2007 | 08:53 PM
tonio5555's Avatar
True, but if my buddy can help me play around with it for free it'd be worth checking out. Thanks man.
Old Dec 21, 2007 | 08:55 PM
D4u2s0t's Avatar
i would double check with halfcent he'll know all about it better than I would. i just remember looking into it when i had the 2.2, but decided it wasn't worth it. if you can mess around for free, nothing to lose though.
Old Dec 21, 2007 | 11:00 PM
not very long ha ha its like under 30 seconds of joy
i top out in less than 17 secs
17 seconds of joy
Last edited by SpeedJunkies07LS; Dec 21, 2007 at 11:00 PM. Reason: Automerged Doublepost
Old Dec 21, 2007 | 11:13 PM
D4u2s0t's Avatar
17 seconds of joy
17 seconds to 112 in a 2.2 don't think so.
Old Dec 21, 2007 | 11:15 PM
RedBaseBolt's Avatar
He forgot the 0 behind 17 so 170 seconds...that sounds about right.
Old Dec 21, 2007 | 11:23 PM
D4u2s0t's Avatar
i think around 30 seconds would be more realistic. i know it took me a long time to get there. never timed it though.
