Turboed 2007 2.2 Cobalts ONLY
I wanna see whats the most somone is running for WHP
my goal with mine is 650WHP i know with these numbers i am going tohave to go with a Stand alone computer set up witch is pricey! going to run about 350 ish this summer then upgrade to a GT42R turbo with a GT28R to spool it. if your gonna flame this then eep it to your self, this is strickly for the turboed 2007 2.2 cobalts |
Lol, unless you have a fully built motor, you won't even be able to run half of that.
Crank starts to go at 500, rods and pistons at 250. |
not to mention axels and fuel pumps and hell alot more upgrades then what it might be worth, id say do the garret kit, do some forged internals and call it at that, espically if its a daily driver and the 300hp range is more than enough for a lilitle speed
ooooo twin turbo?
Just make sure you don't lose any babies in that GT42R.
im a 2.2..........turbo will be an option for me when the warranty is up..........only thing is im and automatic.......anyone have an idea how much a decent turbo set up will cost?
ya im planning on building that 650hp balt myself im getting pretty close to having the motor completely built but this is what i have thus far
http://i172.photobucket.com/albums/w...dallas/pt1.jpg http://i172.photobucket.com/albums/w...dallas/pt2.jpg http://i172.photobucket.com/albums/w...1115081727.jpg i still need: GM Adjustable Cam Gears GM Neutral Balance Shafts GM Hardened Oil Pump Gears Darton Sleeves Fidanza Flywheel Spec stage 3 clutch Port Flow Port and Polish head Clevite main and rod bearings |
Originally Posted by 06cobaltindallas
(Post 3199081)
http://i172.photobucket.com/albums/w...dallas/pt1.jpg http://i172.photobucket.com/albums/w...dallas/pt2.jpg http://i172.photobucket.com/albums/w...1115081727.jpg i still need: GM Adjustable Cam Gears GM Neutral Balance Shafts GM Hardened Oil Pump Gears Darton Sleeves Fidanza Flywheel Spec stage 3 clutch Port Flow Port and Polish head Clevite main and rod bearings You taken it in yet to get estimates on how much the build will be? (labor) |
i havent done that yet but i should get a good deal because ive gotten in good with the guys over at Jotech Motorsports so hopefully. but the head is gonna cost me around 1200-1400 to get ported and valves all installed.
problem im having right now is i need a spare 07 motor to keep from putting my car down |
(Post 3199143)
problem im having right now is i need a spare 07 motor to keep from putting my car down Probably a whole week it will be in the shop I would guess. Man, that's a pretty comprehensive build. |
very comprehensive, but i want it done right you know.
wow. this is gonna be a hard build. you're pretty much gonna have to do whatever they did to get the drag ecotec to run the way it does...lol
keep this thread going and keep us posted i'd love to see it and good luck though, seriously. |
Originally Posted by roadrage06
(Post 3199254)
keep this thread going and keep us posted i'd love to see it and good luck though, seriously. I did notice something. You have turbo grind cams and a fully upgraded valvetrain + Neutral shafts. The powerband on the turbo cams is 2200-7000. You probably should have gone with Stage 3 cams instead and adjustable cam gears. You would make more use of that head work and valvetrain and neutral shafts(since you done need them until about 7500rpms). |
subd for sweetness
(Post 3199227)
Internals will come when I pay this off first, lol. It's just a lot of money all at one time, I can't do it all up front like that. Good luck, I'm waiting on some good numbers out of that thing. |
Originally Posted by ChevyRockstar
(Post 3199344)
subd for sweetness
Originally Posted by Sw4y1313
(Post 3199331)
Its not his thread.
Originally Posted by Sentry
(Post 3199353)
I'm doing all that later, everything is getting boosted and tuned for 7 psi first.
Internals will come when I pay this off first, lol. It's just a lot of money all at one time, I can't do it all up front like that. Good luck, I'm waiting on some good numbers out of that thing. the motor should be done sometime in june |
(Post 3199143)
ya im friends with tony over there and he's been gettin my parts for me.
the one thing weve run into though is tryin to tune it. Kenny hasnt used LS2 edit before so there inlies the problem |
(Post 3199741)
the one thing weve run into though is tryin to tune it. Kenny hasnt used LS2 edit before so there inlies the problem You might just have to get a trifecta tune. |
Why?
no im an 07. i just bought the car in 06. i can see the confusion.
having to send off for a tune instead of some right then and there physically doing it isnt the same. theres way too many variables that come into play and when your spending as much money as i am im not taking any chances on blowing it up |
(Post 3199886)
Dude your wastegate is ginormous holy shit!I plan on doin the garrett kit and a mild build.cometic head gasket eagle rods and low comp pistons and call it a day
im actually going to buy LS2 edit myself here pretty soon so ill have it laying around the house. that way i can learn and change stuff as i go IF i ever need to
