Turboed 2007 2.2 Cobalts ONLY
I wanna see whats the most somone is running for WHP
my goal with mine is 650WHP
i know with these numbers i am going tohave to go with a Stand alone computer set up witch is pricey!
going to run about 350 ish this summer then upgrade to a GT42R turbo with a GT28R to spool it.
if your gonna flame this then eep it to your self, this is strickly for the turboed 2007 2.2 cobalts
not to mention axels and fuel pumps and hell alot more upgrades then what it might be worth, id say do the garret kit, do some forged internals and call it at that, espically if its a daily driver and the 300hp range is more than enough for a lilitle speed
im a 2.2..........turbo will be an option for me when the warranty is up..........only thing is im and automatic.......anyone have an idea how much a decent turbo set up will cost?
ya im planning on building that 650hp balt myself im getting pretty close to having the motor completely built but this is what i have thus far
i still need:
GM Adjustable Cam Gears
GM Neutral Balance Shafts
GM Hardened Oil Pump Gears
Darton Sleeves
Fidanza Flywheel
Spec stage 3 clutch
Port Flow Port and Polish head
Clevite main and rod bearings
i still need:
Darton Sleeves
Fidanza Flywheel
Spec stage 3 clutch
i still need:
Darton Sleeves
Fidanza Flywheel
Spec stage 3 clutch
i still need:
Darton Sleeves
Fidanza Flywheel
Spec stage 3 clutch
You taken it in yet to get estimates on how much the build will be? (labor)
i havent done that yet but i should get a good deal because ive gotten in good with the guys over at Jotech Motorsports so hopefully. but the head is gonna cost me around 1200-1400 to get ported and valves all installed.
problem im having right now is i need a spare 07 motor to keep from putting my car down
Probably a whole week it will be in the shop I would guess. Man, that's a pretty comprehensive build.
wow. this is gonna be a hard build. you're pretty much gonna have to do whatever they did to get the drag ecotec to run the way it does...lol
keep this thread going and keep us posted i'd love to see it and good luck though, seriously.
I did notice something. You have turbo grind cams and a fully upgraded valvetrain + Neutral shafts. The powerband on the turbo cams is 2200-7000. You probably should have gone with Stage 3 cams instead and adjustable cam gears. You would make more use of that head work and valvetrain and neutral shafts(since you done need them until about 7500rpms).
I'm doing all that later, everything is getting boosted and tuned for 7 psi first.
Internals will come when I pay this off first, lol.
It's just a lot of money all at one time, I can't do it all up front like that.
Good luck, I'm waiting on some good numbers out of that thing.
Its not his thread.
the motor should be done sometime in june
Last edited by 06cobaltindallas; 12-12-2008 at 01:41 PM. Reason: Automerged Doublepost
ya im friends with tony over there and he's been gettin my parts for me.
the one thing weve run into though is tryin to tune it. Kenny hasnt used LS2 edit before so there inlies the problem
You might just have to get a trifecta tune.
no im an 07. i just bought the car in 06. i can see the confusion.
having to send off for a tune instead of some right then and there physically doing it isnt the same. theres way too many variables that come into play and when your spending as much money as i am im not taking any chances on blowing it up
Last edited by 06cobaltindallas; 12-12-2008 at 03:18 PM. Reason: Automerged Doublepost
