warped rotors?
Old Feb 28, 2012 | 12:08 AM
joepackersrock's Avatar
warped rotors?
Last summer when I bought my cobalt I insisted on getting the dealer's service records on the car. I was instantly pretty happy because they had replaced the front rotors which I knew have big issues with warping. So now I have driven this car not even 5k miles and the brakes started making a rubbing sound as im coming to a stop. It rubs once every revolution of the tire when applying the brakes. It isn't a grinding or squealing sound either, as I immediately checked the pads which have plenty of friction material left. So the question is, have the rotors warped this quickly? And if so what would you guys recommend I do as far as new rotors and pads so I dont ever have to deal with this again.
Edit: This is a 2007 LS with drums on the rear, its the front brakes making all the noise
Edit (again): Darn, just realized this is in the wrong section...
Old Feb 28, 2012 | 12:12 AM
BankerBalt's Avatar
just replace them. buy a decent set for maybe 40-60 and pads if you need it/can afford it (since they're not that expensive)... everytime you replace your brakes, you should also replace your rotors. so it's not something you should just let go. replace all at once and you should be good to go
Old Feb 28, 2012 | 12:15 AM
David6312008's Avatar
^^^^^Ordering mine wednesday^^^^ Hope this takes care of the damn steering wheel shake when braking
Old Feb 28, 2012 | 12:23 AM
BankerBalt's Avatar
what kind?
Old Feb 28, 2012 | 12:30 AM
what kind?
Found Callehan brake rotors (blanks) and Callehan Ceramic pads shipped for $80. looked at the local parts stores and they wanted $$$$ for pos quality.
Plus Callehan comes with warranty not that it really matters
Old Feb 28, 2012 | 12:32 AM
sorry Callahan brand
here is the link
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Old Feb 28, 2012 | 12:34 AM
BankerBalt's Avatar
right on. never be cheap when it comes to stopping power. when rotors and brakes need to be changed, change them. regardless if they need to be or not
Old Feb 28, 2012 | 12:38 AM
If I was in your place I would go back to the dealer since they are the ones who installed them, however if they were done for the previous owner they will just tell you to buy more and not cover the parts and labor.
Old Feb 28, 2012 | 12:42 AM
BankerBalt's Avatar
they would cost more in labor than the parts themselves. and he's upgrading, therefore he would spend double the price.... brake jobs are easy as hell
Old Feb 28, 2012 | 12:46 AM
let them check them out and then whatever they say is the problem just fix yourself
Old Feb 28, 2012 | 12:48 AM
I actually picked it up at a dodge dealership, they had taken it as a trade-in. So when they installed them they probably had absolutely no idea what they were doing. Also that reminds me of another question I was going to ask. When I was looking at the rotor on the driver's side I noticed that with the caliper off you could actually grab it and wiggle it from side to side. I thought that was a problem, but the passanger side was the same so I just assumed this was normal and the caliper and wheel itself hold the rotor straight...or am I mistaken?
Old Feb 28, 2012 | 12:50 AM
BankerBalt's Avatar
you didn't say for them to do a diagnostic..just sayin... regardless, dealer would probably have charged him for something he could find out himself or buy asking us in this case...oem suspension/braking parts are usually ****.
Old Feb 28, 2012 | 12:53 AM
True im kinda of looking at suspension parts here and there, I just dont want to do a drop because evryone does drops and damn speedbumps are killers round here.
Old Feb 28, 2012 | 12:57 AM
BankerBalt's Avatar
everyone drops because of the outstanding handling you will have... not just for the looks. if you can learn to handle bumps and stuff at an angle, it's not so bad
Old Feb 28, 2012 | 01:02 AM
Angling isnt bad but I drive on some gravel roads that are crap and Im afraid that my girl will bottom it out not thinking and rip off my oil pan.
Old Feb 28, 2012 | 01:08 AM
DiabeticKripple's Avatar
rotors are held on the the caliper and the wheel. if you take the wheel and caliper off, the rotor will slide off just like your wheel does.
Old Feb 28, 2012 | 01:17 AM
Alright thats what I figured, thanks for the assistance everybody looks like I found a use for this years tax money
Jan 12, 2016 12:01 AM
DANRICKARD
Oct 1, 2015 12:08 AM
riceburner
Sep 27, 2015 11:10 PM
Sep 27, 2015 08:53 PM
grampss
Sep 27, 2015 08:51 PM
