Water Temp Sender Solution
Old Jan 3, 2008 | 06:46 PM
tricky1's Avatar
http://cgi.ebay.com/ebaymotors/water...QQcmdZViewItem
This adapter will require you to cut into your upper rad hose and clamp this inline. Then you screw the sender in and wire it up.
I did something similar with a piece of pipe, but I screwed up and put it in the return from the radiator. I'm going to redo it with one of these and get a replacement lower hose. The nice thing about doing it this way is if you screw(like I did) is you can fix it for a few dollars with a hose from Autozone or somewhere like that.
The ID of the 2.2 and 2.4 hoses is 1.28" according to RockAuto. So that means you'd need the 1.25" adapter(which I linked to).
Old Jan 3, 2008 | 07:55 PM
Novajoe's Avatar
cool. Why are you trying to add another temp sending unit?
Old Jan 3, 2008 | 08:16 PM
tricky1's Avatar
No, I'm trying to fix a mistake, I didn't look closely the first time and put the sender in the lower rad hose(return from radiator) instead of the upper rad hose(from head). The water in the return is less than 100*(most of the time). The reading for the DIC is water temp in the head.
Old Jan 3, 2008 | 10:21 PM
mkulrey13's Avatar
thats weird i was told i need a 1 1/2 adapter for my upper rad hose. hmmmm
Old Jan 4, 2008 | 07:34 PM
YSUsteven's Avatar
So the DIC shows the water temp in the head and you want to add a second sensor just after the head. I dint realize that the temp would drop drastically as it ran through the rubber hose to the radiator. What are you trying to accomplish?
Old Jan 4, 2008 | 08:45 PM
tricky1's Avatar
I want a gauge, so I don't always have to keep my DIC on the coolant temp.
Old Jan 5, 2008 | 08:27 PM
YSUsteven's Avatar
So what do you keep the DIC on? Just curious.
Old Jan 5, 2008 | 08:30 PM
Novajoe's Avatar
I dunno about anyone else, but my dic's on 24/7...
sry, had to
Old Jan 5, 2008 | 09:01 PM
mkulrey13's Avatar
Prob outside temp and miles like any normal car...
Old Jan 6, 2008 | 02:20 AM
Jn2's Avatar
Jn2
hmm, nice find, i might do this, i too dontl ike having to keep the dam thing on coolant all the time, i like to keep it at other things too , usually just the MPG
Old Jan 6, 2008 | 10:18 AM
YSUsteven's Avatar
sry, had to
You still dint answer the question, Milage, Trip 1, Trip 2, Avg Milage, Milage to empty. I dint include coolant since you said not that.
Now stop being a dic and answer the question about you DIC, dic.
Old Jan 6, 2008 | 10:33 AM
biniecki's Avatar
nice find. I didnt know they made such a thing. However I think I would rather just install a sending unit in one of the head plugs. This way it wont stand out as much ad the rad adapter. Also are you going with an electronic gauge or mechanical?
Old Jan 6, 2008 | 10:43 AM
D4u2s0t's Avatar
i keep it on coolant.
Old Jan 6, 2008 | 10:53 AM
mkulrey13's Avatar
you cant, will not fit. other pipes are in the way, ive tried
anotherslowlnf
Sep 29, 2015 03:52 PM
Slick_Nick
Sep 28, 2015 09:15 PM
z28addiction
Sep 28, 2015 12:03 AM
metroplex
Sep 27, 2015 07:48 AM
jmelton327
Sep 26, 2015 10:04 PM
