What clutch and flywheel should I get???
Old Mar 5, 2009 | 02:01 AM
PsychoCam's Avatar
I am putting on the garret alpha kit and b4 I do that I am upgrading my clutch and flywheel !!!
I need suggestions on what to get.
I was thinking the spec stage 3 clutch but dont know what flywheel to get.
Using my tax return : )
can anyone direct me to the best combo and where to get it at?
also will I need a throw out bearing or whatever that is also???
Old Mar 5, 2009 | 02:04 AM
Dead Zen's Avatar
dammit chad. you need lsj so you can buy my clutch/flywheel
Old Mar 5, 2009 | 02:08 AM
PsychoCam's Avatar
i know lol there is a ss for sale by me but for the price and milage I would get the one yellow one for sale on here in PA for only 14,500 : (
I have too much dumped into this car to try and trade in and start from sratch lol
Old Mar 5, 2009 | 08:12 AM
06_ion2's Avatar
you shouldnt need a spec 3 unless your making over 300 so get somthing thats a little better than whats already in it.
Old Mar 5, 2009 | 11:07 AM
cobalt_addict's Avatar
spec stage 2+ and a spec flywheel. from what I've heard and read if your getting a spec clutch get the + version its alot better.
Old Mar 5, 2009 | 11:25 AM
PsychoCam's Avatar
so all I will need is a clutch and flywheel? nothing else?
Old Mar 5, 2009 | 12:09 PM
pykie's Avatar
With a clutch i was talking to people around here and they told me to stay far far far away from the spec clutch, but they also own civic's, and teg's, i see alot of people on here run the spec clutch.
i have the Clutch Masters Stage 4.4 six puck clutch, i like it, its very racey and i tell ya, it grabs like no tomorrow.
when it comes to flywheel i was always told to stay away from lighter ones, reason being is that they take your torque away. so i still have my stock flywheel.
Old Mar 5, 2009 | 12:13 PM
koch1ar's Avatar
stage 3 might be harder on you for a DD
Old Mar 5, 2009 | 05:18 PM
PsychoCam's Avatar
ok so if i get the spec stage 2+ should I upgrade my flywheel. I will be around 230-240 hp
Old Mar 6, 2009 | 06:18 PM
PsychoCam's Avatar
bump !
Old Mar 6, 2009 | 08:33 PM
Jn2's Avatar
Jn2
http://www.turbotechracing.com/produ...dcategory=5615
that will hold your power just perfect, and driveability is close to stock, trust me, i have driven with a broken in stgII+ clutch, took me 5 minutes to adjust to it, after that it was straight sailing, my buddy has it on his 2.2sc, and it holds perfect, and leave u room for some impovement should u decide to up the boost past the garrett kits stock settings
Old Mar 6, 2009 | 08:42 PM
blu3_v1p3r's Avatar
You really don't NEED a flywheel. A lightweight flywheel is a great addition though. I just swapped my clutch. I got the spec stage 2.
This is what i bought
Spec Stage 2 clutch (pressure plate included)
Throwout/Release Bearing
DOT3 brake Fluid (for bleeding the clutch)
Manual Trans Fluid (Part Number 88861800 only available through GM parts dealers)
High Temp Grease (to lube inside of release bearing)
Sw4y1313's Avatar
I have a Exedy Stage 2 and I enjoy it a lot. When I first started driving it it was pretty rough but once I hit about 500 miles on it, it feels really nice and smooth. You need to put a bit more leg into it but its very streetable. It will also handle 330ft/tq and cost a lot less then the spec clutches.
Old Mar 6, 2009 | 08:45 PM
blu3_v1p3r's Avatar
Very true about driveablity. My stage 2 is very very close to stock. and it grabs really good.
And turbo tech racing will be your best bet when buying it
Old Mar 6, 2009 | 09:12 PM
Jn2's Avatar
Jn2
i have yet to find this excedy stgII... i dont see it on TTR's site or OTTP, all i see is the excedy stock and excedy STG1
Old Mar 7, 2009 | 12:30 AM
Preston's Avatar
i was told to go to a stage 3 by i think TTR
just because its pretty much the same driveability just stronger
Old Mar 7, 2009 | 12:34 AM
Jn2's Avatar
Jn2
if you want to hold the pwr of stg3 and want good driveablity, pay the extra couple bucks and go with stg2+, holds the same pwr as stg3, with the driveability of a stg2
check TTR's site, they have many clutches with their trq rating on there, just pick the clutch that is, i would say 50+lbs-trq more than what ur planning for, like im planning for 250ish hp, im getting a stg2+ so i can have some play room
Old Mar 7, 2009 | 01:39 AM
PsychoCam's Avatar
ok so what I am seeing my best bet is to go with the spec stage 2+ clutch and stick with stock flywheel. Will the stock flywheel hold up with my power? and also will I need a new throw out bearing?
Old Mar 7, 2009 | 03:25 AM
Jn2's Avatar
Jn2
Stock flywheel holds fine, and yes u need a new tob
Old Mar 7, 2009 | 09:24 AM
TurboTechRacing's Avatar
Exactly what we would have stated.
Old Mar 7, 2009 | 09:31 AM
MP Cobalt's Avatar
So is stage 3 overkill? The car i'm probably going to buy already has a Exedy stage 3 in it
Old Mar 7, 2009 | 09:34 AM
I personally like the 2+ or 3+ better than the SPEC 3 stage... I wouldn't say "over kill", I would state it under drivability and durability.
Old Mar 7, 2009 | 09:39 AM
MP Cobalt's Avatar
So would it be nice for a DD once you get used to it? Or still a total pain in the ass
Old Mar 7, 2009 | 10:33 AM
It is easy IMO to drive the "+" series clutch kits daily.
Old Mar 7, 2009 | 10:34 AM
MP Cobalt's Avatar
So basically it will be a little rougher for me to pull out until I get used to it?
