Wideband bung location?
Front O2 should be in the collector at the end of the header. Wideband bung should be after the flex coupler but before where the cat would be. Then rear O2 would be before the 2 bolt flange. Looks to me as if you dont have the 3rd wideband bung.
If you're not running the rear O2 sensor, then mounting in that location is fine. But if you are still planning on running it, then you're gonna throw the CEL.
n20saturn
Sep 30, 2015 12:26 AM
