2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
headlight!
Old Oct 2, 2010 | 12:27 AM
Ryancobaltss's Avatar
headlight!
ok so just a few mins ago for the very first time removed my headlights.. IT WAS A PAIN!!! but now i got the 4100k from philips looks good and not to white/blue..
what K are you running???
Old Oct 3, 2010 | 12:23 AM
CobawLT2010's Avatar
This really belongs in audio/electronics forum...
but anyways... I dont know what degree k they are but im running streetglow 80/100 watt bulbs... I have a hight temp light harness on it... look almost as blue as prius lights...
The headlight themselves are not that hard to get out... just pull forward make sure you remove the plastic bolts too... top corner ones... gives it a bit more wiggle... When you pull forward make sure you push down the bumper so you dont scratch it... I did that already... but nothing touch up paint and a clear coat cant fix... Then twist the assembly out... Our headlights don't fit well... kinda sux to be honest..
edit: I just put them in two days ago... also make sure you have them pointed right... mine were all wrong from the factory...
Old Oct 12, 2010 | 06:50 PM
RedBaseBolt's Avatar
Ryan,
Good luck with those headlights. I kept blowing them.
I run 6000k HIDs now in aftermarket projection headlights. Mint.
Pasierbek
Dec 10, 2015 07:22 PM
allpro666
Oct 6, 2015 08:11 PM
brickloaf
Sep 21, 2015 02:17 PM
jonnycat
Sep 19, 2015 12:58 PM
