2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Help car cranks but doesn't start. Fuel pump not coming on. At all.
Old Aug 15, 2016 | 08:30 PM
jeffreno's Avatar
Help car cranks but doesn't start. Fuel pump AND relay not engaging at all.
Car has 65000 miles. The fuel pump fuse and relay are both good, inspected fuse and just swapped out both. However, the relay does not click when the key is set to run... All relays I placed in the fuel pump slot won't.
Also, I did a continuity test on relay. Good. However, when I checked my continuity tester on a fuse to see if it lights and is powered, all fuses make the tester light up, EXCEPT the fuel pump fuse. I was checking everything else b4 changing the fuel pump...
Is this an electrical problem, or just a bad fuel pump? Thanks in advance.
Last edited by jeffreno; Aug 15, 2016 at 11:04 PM. Reason: Better title description
Old Aug 16, 2016 | 10:13 AM
jdbaugh1's Avatar
This video helped me when I was diagnosing fuel delivery problems on my truck.
Old Aug 30, 2016 | 08:26 PM
Firefighter776's Avatar
I took my relay out and blew in the slots where the relay plugs in and wiped off the prongs on the relay and haven't had a problem since
Old Aug 31, 2016 | 08:19 PM
no_ss's Avatar
Electrical problem. If it were making a complete circuit it would light up.
Buy a multimeter and test and see if you have voltage going through the fuse. Be careful playing with amperage. You can blow the fuse in the multimeter if you choose to get one.
Ryans09SS
Jun 10, 2024 12:09 AM
Manopka
Mar 22, 2016 04:34 PM
flobeelicious
Mar 13, 2016 08:56 PM
dougl122
Mar 7, 2016 07:08 PM
RedCavyRS99
Oct 15, 2004 11:43 PM
