2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
need help with map sensor.
Old Oct 25, 2012 | 10:34 PM
J-Jeezy's Avatar
so i need help wiring up the 4 pin 2.5 bar map sensor to my stock map and maf sensors. for anyone that has gone sc with there LAPs have yall done this.
Old Oct 25, 2012 | 10:44 PM
bluebalt07's Avatar
Here's the diagrams that you will need. Because I don't feel like typing much I won't explain it in great detail but basically just take the wires from your stock map harness and connect to the correct pin on the LSJ harness and then take the wire from the MAF that says IAT and connect it to the IAT2 wire on the LSJ map
Old Oct 25, 2012 | 11:07 PM
J-Jeezy's Avatar
awesome thank man! will this work with the bosch harness then? just match the pins right?
Old Oct 26, 2012 | 01:45 AM
bluebalt07's Avatar
Yep it's as simple as that
Old Oct 26, 2012 | 11:58 PM
J-Jeezy's Avatar
Got this installed tonight and had the ecm retuned to recognize it. Thanks for all the help!
DarrenGC
Dec 24, 2021 01:55 PM
Tupp
Jan 2, 2016 12:04 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
Shane H
Sep 19, 2015 11:28 AM
