nhanson's S/C build
nhanson's S/C build
So this is a little early but want to clear up questions before i actually need to install. Also will be slowly buying parts over winter.
Think I'm going to skip straight to 60 lbers and a 2.9 pulley. Knowing this, will/should i do dual pass and option B right away? Ill be using ZZPs S3 heat exchanger without the stock heat exchanger.
Does it matter what intercooler pump I get? i noticed Gene had the ford racing so is that one better?
Probably will skip buying rims, tires, and drop just to get this done. Sleeper style
60s and 2.9 is perfect for a 2.2. stenguyen here made 255whp with that combo. I would do dual pass option B right away for the simple fact that Opt. B bleeds so much faster than the stock LSJ coolant setup. ZZP S3 H/E is also the best H/E you can get short of a griffin. All good stuff.
The ford racing pump is the exact same pump the cobalt uses by default. It is in fact a ford part.
Sleeper ftw!
Sleeper ftw!
I run a ZZP 2.9 with 60's and a bit of E85.IAT's?Hmm should be dam low.Can't tell since I'm running the stock MAP sensor which doesn't read temps.I'm on stock endplate and the huge ottp dual pass H/E
Yeah the GM one is not a cast piece or anything special. They make theirs the same way all the vendors make them: Drill a hole, add a fitting, make sure there are no clearance issues, and make sure it doesnt leak.
I'd get one for the lowest price you can find. ZZP is a good place to get one. ItalianJoe1 here on ss.net made mine.
LSJ SC Coolant Reservoir
LSJ SC Coolant Reservoir Cap
LSJ SC Coolant Reservoir Bracket
LSJ SC Coolant Reservoir Overflow Hose
LSJ SC Coolant Reservoir Inlet To Top Intake Manifold End Plate Hose
LSJ Bottom Intake Manifold End Plate To Intercooler Pump Outlet Hose
are these items replaced with option B?
so if i started with option B these wouldnt be needed?
Bought ZZP S3 heat exchanger and dual pass plate!
using the lsj 2 bar map is the best way cuz it gives him more tables to look at to dial in your tune much better and see iat2. I have a lsj map on my car and i see aroun 69 degrees cruising and after a wot pull i see 100 to 110 degrees max. as long as you run a good coolant mix and have your pump working you can see a big difference in cooling.
