2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Oil Change
Old Nov 12, 2008 | 09:56 PM
Cobaltxfe09's Avatar
Exclamation Oil Change
Well i changed the oil in my '09 2.2 the other day. After doing some reading on this site and (thanks to MAVEN) I switched from the regular oil that came from the factory and put MOBIL 1 5W-30 and an AC DELCO oil filter. The reason i did it early was because i found that when driving the car in first gear i couldn't go above 4500 rpm without the sounding like it wanted to kill me. I knew it wasn't the tranny so i did the oil. I tell you what...what a difference. I can drive in every gear above 4500rpm with out a problem. I know its not normal to redline in first gear under normal driving conditions but now i can and not have to worry. I live in Pittsburgh and its getting cold in the mornings and i found it runs better under cold conditions also. I also noticed a difference driving in all other gears too. It just seems like it got a little more...ummm...pep. I know it sounds stupid but its the truth. So to all us 2.2 owners....MOBIL 1 5W-30 and an AC DELCO filter is the way to go. It cost me about $45 for the oil change i got 6 qrts of oil and the filter...(5 for the change and 1 for the trunk). thats not bad. Good luck to all.
Old Nov 14, 2008 | 03:21 PM
usmcseanash's Avatar
thanks its about time for me to change my oil and i think that i ll go and do that thanks man
Old Nov 14, 2008 | 04:08 PM
Cougarguy's Avatar
thats completely understandable. synthetic does in fact offer the ability to lessen the resistance in your engines rotating assembly.
Old Nov 14, 2008 | 04:29 PM
_UnLiMiTeD_'s Avatar
mine ran smoother with synthetic. Mine felt awesome because my ******* dealership put in regular gas and crap oil. So when i switched my SS over the premium fuel and synthetic oil it felt like it was a whole new motor in it.
I always use synthetics in my cars, they run much better and its better for the motor anyways
Old Nov 17, 2008 | 10:36 PM
jlong3382's Avatar
Mobil 1 5W-30 and AC Delco Filter FTW!!!
Old Nov 19, 2008 | 04:00 AM
Jn2's Avatar
Jn2
has the engine been broken in yet? i wouldnt rev that high on a new engine, i waited till i hit 5k before i started doin redline shifts...the first 3k i shifter no later than 4k, after that i did a few hard pulls, but ever did it often
Old Dec 1, 2008 | 11:28 PM
well i have about 2400 miles on it now. i would say it is close to being broken in. i have driven it like a grandma since the first time i drove it off the lot. Only a few times here and there have i got on the gas(of course). but MOBIL 1 is the way to go and just wanted to point everyone in the right direction. thanks guys.
Old Dec 2, 2008 | 01:06 AM
Jn2's Avatar
Jn2
good luck, mobil is a good oil i ran the mobil 1 full sythetic on mine, never had a problem, ran that to 30k, now i run royal purple
Old Jan 27, 2009 | 03:20 PM
xxxxsh4d0wxxxx's Avatar
I could be wrong, but I'm 99.9% sure my car came with synthetic oil in it to begin with.
Old Jan 27, 2009 | 04:17 PM
css9450's Avatar
Skeptical.
Old Jan 27, 2009 | 04:38 PM
the 2.2 does not come with mobil from the factory, just standard oil. only the ss/sc and the ss/tc(i believe) come with synthetic from gm.
Old Jan 27, 2009 | 06:55 PM
Well, my dealership kept insisting that I didn't need to change my oil till 5,000-6,000 miles.
If that was the case, they would change it at 3,000 miles; hence making them more money.
Old Jan 28, 2009 | 08:47 PM
jlong3382's Avatar
My dealer tells me i don't need to change my oil til the DIC tells me to. However I still change it every 3,000 miles (and yes I use Mobile 1). But I do nothing but stop and go driving with my longest weekly trip being 9 miles on way.
Old Jan 29, 2009 | 09:21 PM
unijabnx2000's Avatar
Im waiting for my first oil change in my XFE also. I dont get on ground anymore tho to drain oil.
I use this
Old Feb 25, 2009 | 06:12 PM
cobaltguy88's Avatar
^ cool
Old Feb 25, 2009 | 06:15 PM
PinaSS's Avatar
I use this
kool where did u get that?
Old Mar 2, 2009 | 03:51 PM
amazon.com
$52 with free shipping!
BTW
Used it yesterday.
First oil change @ 5774 miles
5qts of Mobil 1 5w-30 and Fram oil filter = 29.99
30 mins to change oil with out a mess = priceless
Old Mar 3, 2009 | 12:47 PM
Maven's Avatar
Ive never liked changing oil that way. Yeah its clean, yeah it saves putting the car on ramps/jack/whatever, but you get more oil out when you use the drain plug, Ive tested it numerous times, I love my Evac tank for coolant and for other servicve procedures and things....but NOT for oil changes. Also, the wand doesnt really like super hot oil....itll get deformed eventually. :personal experience:
Old Mar 3, 2009 | 01:47 PM
HunterKiller89's Avatar
for the last point...wouldnt the simple fix be to just do an oil change with a cool engine...?
Old Mar 3, 2009 | 05:55 PM
I know if I pull my drain plug after i use it no oil comes out. So I know it gets it at least below the drain bolt. (which is just as good as using it or better)
Old Mar 3, 2009 | 06:31 PM
Maven's Avatar
yeah, except your supposed to change the oil with it at operating temp.
Old Mar 3, 2009 | 10:32 PM
.....touchet
Old Mar 4, 2009 | 03:48 PM
victoryss's Avatar
That is a very accurate statement. But it can be hot so wear your gloves!
Old Mar 4, 2009 | 04:00 PM
Maven's Avatar
I aim to mame. err, no wait, I aim for accuracy.
Old Mar 4, 2009 | 06:51 PM
Derwood's Avatar
I've only had my car a little over 3 months now and i'm due for my second oil change (i'm at 11,302km). I use Royal Purple 5w-30 and a regular AC Delco filter.
It costs a little more but I noticed better gas mileage and such in my LS1 Camaro, so I'll keep using it.
* Also, apparently you're supposed to drive you brand new car pretty hard, it helps seat the seals better. They told my dad to drive the snot out of his CTS for the first while instead of baby it, and they told me the same.
