2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Ssssssssssssssss
Old Jul 22, 2012 | 04:27 AM
Ryancobaltss's Avatar
Ssssssssssssssss
like they title says... so my car makes a ''slight'' hiss sound when i rev/give it gas.. ALMOST like if a turbo was spooling up. not trying to make it sound like its cool but thats the closest thing i could say it sounds like.. anyone els got this going on? and no its not a ''tik'' sound from DFI.
thanks!
Old Jul 22, 2012 | 04:42 AM
Maccoy316's Avatar
intake leak?
Old Jul 22, 2012 | 08:24 PM
So i checked for leaks and nothing.. then i opend the hood and had a friend rev it a bit and its coming from the belt area... then i looked UNDER the car where the belts are and its coming from UNDER the car. hmmmmm.
Old Jul 22, 2012 | 09:01 PM
Ceej's Avatar
Test for a leak in the downpipe. Are you throwing any codes?
Old Jul 22, 2012 | 09:05 PM
2009CobaltLT's Avatar
It's a normal sound, a lot of people have asked about it and we all came to the conclusion that it is the sound of air passing through the TB
Old Jul 22, 2012 | 09:07 PM
Just saw your other post, maybe it's different since its coming from under the car. But same sound, like a turbo spooling
Old Jul 22, 2012 | 09:35 PM
no codes or anything thank god lol and if others have said they have this to im sure it should be ok X)
and i have checked all points where air of any sort could escape and nothing. ill keep this updated if it gets worse or i find out why this is going on. thank you all for the help
Old Jul 22, 2012 | 09:46 PM
Ceej's Avatar
Cause my exhaust leak sounds like a turbo spooling a little bit, that's why I threw that suggestion out
Old Jul 25, 2012 | 03:33 AM
Crav3's Avatar
My brother was fixing an eclipse and it was making this sound too. Turns out its turboed lol
Old Jul 25, 2012 | 04:55 PM
Synickle's Avatar
Had a friend with a 2.2 ecotec grand am that was making a hissing noise. Turned out to be the ac compressor. The pulley had seized, and was causing the noise.
Old Jul 25, 2012 | 05:00 PM
turbosmart4's Avatar
Check exhaust mani. I had a car makin a noise like that(made me feel cool) trned out being a cracked mani
