Full cooling mods. My car has never heat soaked and you don't have to change the pump for e85. Stock is fine.
Yea when my brother had the s3 heat exchanger it ran amazing, then when he broke it exiting his driveway the car didnt run the same. I do have a dual pass but i dont think it helps much without a bigger HE.
Really? I had read about LSJ cobalts switching out the fuel pump for e85. Your making me want to switch to e85 lol. I just dont want my motor to blow up. Its not as strong as the 2.4 |
No one swaps their fuel pumps lol unless they go tvs and bigger numbers. I was on the stock one 2 years. All my friends are too. I recommend getting the ottp h/e. The zzp is garbage. It bends so easy and cracks. I broke mine and bent it. Replaced it with ottp. So much stronger and made better. I've scrapped it a lot. Also cheaper.
Also, dual pass is the most important part. The stock h/e is actually enough.
Wow i did not know that. Ill keep it in mind if i ever do go e85. I really wanted to get an lnf but then i lose one race and i want to build the g5 better and stronger.
was thinking of getting the cx racing HE, it was like $130 i think. A friend had one and it was not bad.
(Post 7657799)
Lsj and turbo swap it
I want to get an lsj and turbo it and put it in a miata. Also currently on the look out for a low priced miata to start an ecotec swap on it. Also know of a guy who took out his lnf and dropped in an LDK into it. So maybe ill pick that up if i find a miata.
I wonder if you would even be able to reap much benefit from E85 as the rods in 2.2's like to bend.
Ecotec swap Miata's are bad ass. There is one stripped down purpose built Ecotec Miata that I see at autocross events on slicks with a turbo ecotec and the thing flys around the courses. Honestly is right up there with the Exocets or other tube frame builds. |
I can't think of any stock motor 2.2s I know that are running e85
But I don't think e85 and a sc kit is going to make enough power to bend a rod. You will till be under 300hp
(Post 7657849)
That's what people say and it's not true. I know a few people that have more
(Post 7657855)
The 250 number came from GM testing with a nitrous shot. Using a blower the power gain is different. You'll run cooler cylinder temps on e85 so that might help prolong things
Originally Posted by ECaulk
(Post 7657912)
Originally Posted by jdbaugh1
(Post 7657844)
Ecotec swap Miata's are bad ass. There is one stripped down purpose built Ecotec Miata that I see at autocross events on slicks with a turbo ecotec and the thing flys around the courses. Honestly is right up there with the Exocets or other tube frame builds. nitrous does not start to get harsh until after a 100 shot at a time. That is why they make stage kits. Its easy to take 2 small hits one after an other than one huge hit at once. I seen a 5.3 silverado take a 250 shot and blow up while another had a 2 stage kit spraying 150 shot then another 100 a bit after and survive many runs. yes i seen few ecotec miatas on youtbe and i gotta say im impressed. Even a stock 2.4 can run with turbo 1.6, 1.8 miatas. An lnf or lsj turbo in one would be crazy |
Originally Posted by Crav3
(Post 7657919)
i remember back when i got my car around 2011 there was a guy running full cooling mods 2.9 pulley and e85 on a 2.2 LAP and only lasted a couple weeks before he bent a rod. That is why i dont want to do it just yet.
(Post 7657915)
When tuned correctly isn't a nitrous shot more healthy than boost from a supercharger because it is adding oxygen without additional heat and pressure?
(Post 7657920)
The Miata I was talking about I think started with a 2.4 Ecotec and was very impressive them. Definitely enough power for autocross IMO. This year he is turbo'd and it went from impressive to nuts.
