The connector did make one more click.
Started seeing 14.5 to 14.8 now more fluctuation. Not as much as I expect yet... will see if I can do more after work. See if it shows some real numbers made my ground a little better too... |
When your key is on but the engine isn't started where does it sit?
14.6
Somethings fucky. Should see big swings at startup and it should bobble around pretty good with throttle transition.
Yeah that’s my expectation of what I should be seeing.
Well if it doesn’t rain tonight I will re-do everything. The ground should be good. It’s obviously getting power. Its the communicauon between the sensor and gauge. Maybe there’s a pinched wire somewhere. |
Originally Posted by G5ALIVE
(Post 7715228)
Fun fun fun , never a dull moment with this car lmao.
Ill let you know if I figure this one out Again thanks for all the advice JDBaugh1 |
So after talking with AEM technical support, I mentioned the gauge read 14.4 when disconnected from the sensor.
After I said that, they said to destroy the gauge and a courtesy replacement will be send. I really needed a win here, I’m happy 😃 again guys |
Damn sounds like you have about the same luck with bad parts out of the box as me. At least AEM stood behind it.
Very cool of AEM to stand by their product.
Oh I have some pretty bad luck.. Lot more wrong parts here then defective.. Lot of parts that say “fit” that require more or really “don’t fit” |
(Post 7715439)
^^^ definitely true. Kind of fitting but with slight modification required is pretty standard especially with a 2.2 as far as aftermarket parts go.
Meh I won’t dwell in the past. Too much suffering lol
Well...while I wait for the new AEM gauge to arrive. I will be brining my car into a transmission shop tomorrow for an inspection. Hurray! |
The warranty replacement AEM gauge came in today, plugged her in and it works!
Will see if tomorrow I can see what its reading at WOT. for the most part I saw around 14.0 to 15.5ish driving home normally Will also be looking to see what my air fuel is when I get a high idle or surging going on.. In the works of getting together the cables and adapters to read the wide-band inside VCM. |
WOT from 10km/h to about 70km/h it reads 10.00 (which is the lowest point the gauge will read)
So its probably a little rich at WOT.. I would expect to see 11.58 (commanded) or 12 something. Better to be rich than lean I suppose lol This is probably why I'm going through fuel like crazy hahah Definitely need to revise the tune with the wide-band |
(Post 7716000)
(Post 7716000)
Originally Posted by ECaulk
(Post 7716004)
That's way rich, def need to get that leaned out.
And if the gauge is bottomed out at 10 it is probably even lower which is getting rich enough to cause it to run poorly, possibly even wall wash. Like Ecaulk said that is way too rich. I wouldn't even drive WOT until you get that adjusted. |
appreciqte the advice, will not boost anymore until resolved.
Okay got all the cables! They work.
Had a little hiccup today though. Installed the data logging cable and proceeded to see if it works. The inter cooler pump begun to howl. So I removed all my wires initially and it still howled. So I begun checking wires specific to the pump, pump looked good, hoses were on, no leaks anywhere.. So I poured about 125ml into the "fill" hose. Waited about ten minutes and it stopped howling. Very Weird. But anyway, should be tuning again this week! |
(Post 7716156)
yeah probably just an air pocket.. the pump is only a few months old.
I have checked on the fluid a few times since install but perhaps I should be checking more frequently. |
Originally Posted by jdbaugh1
(Post 7716012)
Got my first update, yesterday, from Matt. Brought the air fuel just up above 10.00 where we could see some actual moving figures. WOT was hovering around low 10s at that time. Got revision 2, today, over lunch. At looks like 6-7psi it's now at about 11.6 - 12.10 It feels a lot more stable/ smooth |
Spent all Saturday installing an AEM 30-3300 water meth system. Fabricated a bracket for the trunk to hold the tank and mounted the pump in the spare tire storage.
I validated the system worked before removing the power sources as I want to install on/off switches and In addition I ran into a fitment issue with the long injector nozzle and the placement of the nozzle taps in my adapter plate for the throttle body. I looked at the adapter plate for awhile making sure I didn't have it backwards with taking in consideration of the seals: the only way everything lines up is with the taps on left and top side. Which seems odd because I feel the right and bottom side would be much easier.... This isn't my car but I guess I'm not crazy and my engine bay is just tighter than most https://cimg5.ibsrv.net/gimg/www.cob...05df1722a5.png his taps are on the top and left too.... Anyway I ordered two switches and a 90 degree fitting from work that should be here tomorrow, hopefully that will solve my clearance issue without needing to drill holes in the rad support otherwise I should be a able to test the system again soon all assembled, Also need to swap out those clear zip ties with black... lol I found a retailer I do business with to carry AEM products so couldn't say no to the price it was a steal! didn't even pay shipping ! woot! https://cimg1.ibsrv.net/gimg/www.cob...a84bc798f2.jpg |
If I understand correctly you are having problems with AEM's straight fitting which the nozzle threads into. Are you using quick connect fittings? AEM is probably like DevilsOwn and sells both right-angle and straight fittings. If you bought a generic fitting from your work make sure they will be corrosion resistant to the methanol.
EXACTLY^.
Not really a big issue, just documenting my build... I ordered part number LGR36095611 from acklands, was about 8 bucks MALE ELBOW 1/4 OD X 1/8 NPT. claims its "Designed specifically for use in food processing applications. Excellent chemical, corrosion and abrasion resistance. FDA approved. Maximum working pressure: 7 to 290 PSI. Temperature range: -4 degrees to 250 degrees F. FKM gaskets." made of Nickel Plated Brass think I made the right choice haha? or should i have went with plastic? |
