turbo weld on...
what would be the down side to have a shop weld on a turbo to my stock DP and header?
thanx XD |
lawl
im going to LAWL if i do it? XD
Man just do some research, your stock mani will not support a turbo. Check out zzperformance.com
locate yourself a equal length manifold lol.
guys, he's talking about putting the turbo on his dp... like sts turbos.. I would get a bracket for the turbo welded on so one day it wont just break off or leak. could work..
he said "stock downpipe and header" if you put it on the header might as well get a manifold
if it blows or seizes you're gonna have to spend even more money
Originally Posted by sundevil07
(Post 5177161)
:lol: just got the question.. just get a turbo manifold, don't rice that out dude.
get the manifold, turbo, and get the adapter that Garrett makes to bolt the turbo to the stock dp.
do it... it'll work GREAT!
:wtf: do it right or don't do it at all. i recommend zzp
heres a good idea. save your money and get an ss :) makes alot more sense than trying to make an ls fast...
Uh... I wouldn't do that. If your turbo shits out, you're out a manifold too.
Originally Posted by BIGGSS_SuperCharged
(Post 5178057)
(Post 5178057)
The best option for you if you must go that rout is to have a shop weld a t3 or whatever flange the turbo requires and bolt the turbo to it. The only problem with this is having clearance to mount the turbo.
