2.4 forged internal options
Old Sep 22, 2009 | 01:15 PM
Zdeuce4's Avatar
It seems we have everything else covered mod wise for 2.4s but what can we do as far as forged internals?
for all the boosted people that would like to make bigger numbers where are the places we can get pistons and rods? the only one i know of right now is imporperformanceparts.net and it comes with some other stuff.. my only concern is i dont want to drop compression that much. id like to keep stock cr or the lowest 9.5 or so. i need to call and ask if they allow you to have other compression options.
since we have forged rods according to the gm spec sheet i was considering just getting pistons, head studs and getting my rods cryo treated to strengthen em up. i also plan to have a p&p head, 3 angle valve job, supertech valve springs and arp head studs.. i think thats all for now. then ill throw in a larger turbo.. wut are the other small things that should be added when rebuilding the motor and if anyone knows where to get more forged parts for the le5 post it up!
Old Sep 22, 2009 | 01:23 PM
Dunkinuts's Avatar
not a bad kit price. good find.
Old Sep 22, 2009 | 02:33 PM
Zdeuce4's Avatar
ya its not bad... if all else fails i guess i could go with this and the low compression.
Old Sep 22, 2009 | 03:37 PM
Dunkinuts's Avatar
I got a quote a long time ago for custom pistons and they were $600-700 just for pistons.
Old Sep 22, 2009 | 03:51 PM
Zdeuce4's Avatar
fock.. thats alot.. but like i said.i may just get pistons and cryo treat some oem rods since theyre forged.. im not planning on doing much with the block. so it may cut the price down slightly.
Old Sep 23, 2009 | 03:48 PM
Zdeuce4's Avatar
someone else has to care about internals.. its amazing how many intake,header, and exhaust threads get more hits than this.
Old Sep 23, 2009 | 04:13 PM
Dunkinuts's Avatar
I think it was for my ranger so a 6 cylinder. but still high.
Old Sep 23, 2009 | 04:14 PM
Zdeuce4's Avatar
i wouldnt mind 500... oem rods are like 60 each. i could get em cryo treated for prolly 100.. then call it a day on the block..
Old Sep 23, 2009 | 04:19 PM
Dunkinuts's Avatar
yeah that is one reason to stay N/A
Old Sep 23, 2009 | 04:27 PM
Zdeuce4's Avatar
f that.. na is too slow.... the time period between my turbo being busted and driving na for awhile sucked.. now that im boosted again. ill never look back. the only way id enjoy an na car is if it was a high hp v6 or v8
Old Sep 23, 2009 | 05:35 PM
riko540's Avatar
Sorry to break it to you but Wiseco doesn't offer pistons for the 2.4L or atleast their catalog doesn't show them. Here is the PDF if you don't believe me.
http://www.wiseco.com/Catalogs/Sport...undaiMazda.pdf
Old Sep 23, 2009 | 05:39 PM
Zdeuce4's Avatar
another member bought that kit that i posted up so ur not breaking anything to me. he got the low compression pistons with it.
Old Sep 23, 2009 | 10:34 PM
mmcgee123's Avatar
They do make pistons I've called them n talked to a rep eagle also makes rods for like 600
Old Sep 24, 2009 | 12:00 AM
HunterKiller89's Avatar
IIRC crower makes rods for the LE5...someone definitely does. And then you can always call weisco and they'll make custom pistons for any application. Problem solved
Old Sep 24, 2009 | 12:06 AM
weisco will make custom pistons for any ecotec application in any bore, in any CR. Just gotta call em. Im pretty sure Crower made rods for the LE5 as well...i know someone definitely does (but theyre mad expensive compared to L61 rods)
EDIT: stupid server
Old Sep 24, 2009 | 12:18 AM
Zdeuce4's Avatar
the crower rods are expensive too? as in more than the $600 eagle rods?
Old Sep 24, 2009 | 01:12 AM
might've been the eagles i was thinking of.
Old Sep 24, 2009 | 01:14 AM
Zdeuce4's Avatar
shoot thats still not bad.. i guess ill save up about another 2k while im cruisin around with 300whp.. get some pistons and rods, and get some headwork done all on the spare motor. then ill be ready to go..
are there any other small things that should be done when trying to build up a motor?
Old Sep 24, 2009 | 08:39 PM
Josh@ottp's Avatar
We can get 2.4l pistons from diamond, wait time is 2-3 weeks. Price is $40 more than the lsj pistons.
Old Sep 25, 2009 | 02:22 AM
Zdeuce4's Avatar
thats wtf i like to hear.. lol how come the le5 gets screwed on price? any compression?
and wut would u suggest? i was considering dropping to 10.0 or keeping stock comp. i like not needing alotta psi
edit.. CRAP thats a good price.. i know who's supplying my pistons.
my next question is what other parts should be coupled with the pistons and rods?
Old Sep 25, 2009 | 02:30 AM
elecblue06's Avatar
i'm only interesting with 10:1 at the very lowest
Old Sep 26, 2009 | 03:31 AM
BoostedG5's Avatar
sig.
Old Sep 26, 2009 | 09:07 AM
Zdeuce4's Avatar
dang carillo rods for 1k.. i may have to look into those or eagle..
Old Nov 6, 2009 | 02:40 AM
RDKDESIGNSG5's Avatar
wiseco pistons/carrillo rods
i have a brand new set for sale.. 1ooo.00 total
Ryan
Old Nov 6, 2009 | 03:54 AM
Zdeuce4's Avatar
if i had the cash id definitely scoop that up. looking to build next yr.
