2.4 nitrous project
Old Sep 19, 2008 | 09:48 PM
mmcgee123's Avatar
2.4 nitrous project
so i have a 2008 cobalt sport and i wanna do a 75 wet shot nitrous set up and i was just wondering what all i need to buy i kno i need one step colder plugs and im gonna do a catless dp with a AEM wideband 02 but is there anything else besdies the kit that i really need ?
Old Sep 19, 2008 | 10:15 PM
rockstar014's Avatar
october 5th someone is installing my wet kit to my 2.4L and i think that is all you need is the kit
Old Sep 19, 2008 | 10:19 PM
nikebaseballx00's Avatar
window switch, it should come with the WOT Sensor or whatever its call
also u might want a bottle warmer, and opener if its in ur trunk
Old Sep 20, 2008 | 08:54 AM
REDFOCZ's Avatar
you will also need an electronic tps sensor because of the throttle by wire on are cars
Old Sep 20, 2008 | 09:13 AM
originaladrian's Avatar
think u got everything, make sure to buy a window switch.
on another note- that catless DP is going to make ur car sound like complete ****.
redssna's Avatar
You'll need the kit itself, a window switch, depending on the kit you'll wanna pick up an electronic throttle position switch (most come with the manual switch under the pedal). You could spray with those parts but a bottle warmer is a great idea if you want consistency. Most tracks I believe require a blow down tube. And a purge kit and remote bottle opener are nice things to have. Plus the step colder plugs as you mentioned.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
patooyee
Oct 15, 2015 05:11 PM
z28addiction
Sep 28, 2015 12:03 AM
Rduncanss06
Sep 27, 2015 11:17 PM
Bohb
Sep 27, 2015 09:11 PM
