2.4 t/c s/c spark plug recommendations
Old Sep 6, 2009 | 05:10 PM
bainecotec's Avatar
What kind of plugs are you guys running? For 1 step colder. I'm having trouble finding an NGK,copper, and 1 step colder.
Old Sep 6, 2009 | 05:53 PM
celicacobalt's Avatar
check my link in my sig
Old Sep 6, 2009 | 09:12 PM
mtbrent's Avatar
Would it not have been easier just to type LZTR5A-13? Those are not one step colder anyways, they are stock heat range.
To the OP, LFR6A-11 is what most use for 2.4 boosted apps. They are one step colder and copper.
Old Sep 6, 2009 | 10:42 PM
IonNinja's Avatar
Guys are having success with these? I just looked them up and they appear to be about 1mm longer than stock. Do you run them?
Old Sep 7, 2009 | 12:30 PM
mtbrent's Avatar
That is something I never noticed until now lol. These are the plugs pjk91 and beck told me to run and they have held up fine in about 28k that I have since going m62. I put a fresh set in at 20k and the electrodes looked normal, but the gap had widened from .038 to about .041ish in those 20k miles. Apparently that 1.0mm extra reach is ok.
Old Sep 7, 2009 | 12:50 PM
elecblue06's Avatar
well there are a few kinds...
one is the cheap route.. champion 430 530 or 420s they're from the srt 4 neons, or hemi trucks these are copper plugs
and the others are whats been posted so far .. i have some iridium but i can't remember the part number off hand
Old Sep 7, 2009 | 01:59 PM
I have tried the lfr's and was not impressed, having better luck with the lzt's on 14 psi.
Old Sep 7, 2009 | 05:11 PM
IonNinja's Avatar
Cool, ill have to give them a try then. I'm assuming they'll be fine for 2.2s as well since they both run the same size plugs stock.
Old Sep 7, 2009 | 05:12 PM
Zdeuce4's Avatar
i got the autolite iridiums from zzp
Old Sep 7, 2009 | 05:14 PM
pjk91's Avatar
Still running LFR6a-11. gaps open over time.
Old Sep 8, 2009 | 08:31 PM
Gene Culley's Avatar
Talking
I didn't realize these were one step colder. This is what I'm running on my 2.2 LAP setup. They are fine.
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
