42lb injectors and spark plugs
Old Aug 26, 2007 | 08:45 PM
mike25's Avatar
ok well i was wondering as far injectors go....i want 42lb injectors...but which harness do i need?...i was looking at this sight an this is what they are selling...would it work with my car?...http://www.lightningforceperformance...kit-p-520.html......what harness do i need?
and also what spark plugs should i look at?...or are the standard plugs sufficient to handle boost?
Old Aug 26, 2007 | 08:58 PM
jgarciarivera's Avatar
There seems to be a discussion on injectors here:
https://www.cobaltss.net/forums/show...ighlight=310HP
You will be alright with just stage 2 and 42's. You can use NGK Spark Plugs (BKR7e). It's recommended to use 1 step colder but not necessary. CA has them. Those LFP look ok to use. If you are going to spend on 42's, I suggest you spend a little bit more to get some 60's. Just my thought.
Also check this out,
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/logs-they-may-scare-people-%7B56k-nope%7D-72935/
Jose
Old Aug 26, 2007 | 09:47 PM
pjk91's Avatar
I went with stage 2 42's. To use any injectors made for the ss/sc you need the injector harness from an 03-05 cavi or sunfire.
for plugs: i haven't got the s/c in yet, but i have a set of NGK copper plugs meant for the turbo 2.4 solstice guys. I'll get you a part number when I get put them in tomorrow.
Old Aug 26, 2007 | 11:12 PM
iLLmaTic3s's Avatar
are u a 2.4...if ur not going s/c or really t/c u wont need 42's...32's will do the job..the 32's are the stock ss/sc injectors
Old Aug 27, 2007 | 12:09 AM
pjk91's Avatar
2.4 s/c, and I'm using 42's as an extra cushion when I upgrade.
Old Aug 28, 2007 | 07:47 PM
mike25's Avatar
same for me...i havent started with the build yet...but i want to be in safe range with tthe injectors rather than close to over doing it....
Old Aug 28, 2007 | 09:02 PM
JohnyNFullEffect's Avatar
You need the 2.2L Cavi Harness
GM Part #15411879
$74.80 total from GM Parts Direct
http://www.gmpartsdirect.com/
Old Aug 28, 2007 | 09:12 PM
mike25's Avatar
and that works with the ss/sc injectors or any injector for that matter?
Old Aug 28, 2007 | 09:13 PM
pjk91's Avatar
any injector made for the ss/sc...
so it will work with the stock 32's the stage 2 42's or the 60's (are there 60's from gm?)
Old Aug 28, 2007 | 09:38 PM
mike25's Avatar
hey pjk hit up your build thread i have some questions for you....as for the harness...thats a good thing ill save some money then
Old Sep 2, 2007 | 08:56 AM
mike25's Avatar
can i pick up a new set of 42's for a low price or do i have to buy them used...anybody know?
Old Sep 2, 2007 | 12:52 PM
pjk91's Avatar
I'm not sure how much they go for new, but USED I paid $90 shipped.
Old Sep 12, 2007 | 01:03 AM
yoppzilla's Avatar
I acually am probally making this my first mod/ with a nice tune
Old Sep 12, 2007 | 09:57 AM
pjk91's Avatar
Shouldn't need 42's or 34's for that matter if you aren't boosting. A tune would help though.
Old Sep 13, 2007 | 01:13 AM
yoppzilla's Avatar
yeh man I ment the stock ss/sc headers not the 42s and from what I here Putting them on with the 04cavi wireing harness and tune is only tune worth getting so far
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
