View Poll Results: Which one should I get?
Magnaflow Cat-Back
43
59.72%
Eibach Sportlines
29.17%
Header (Cobalt Addiction Most Likely)
11.11%
Voters: 72. You may not vote on this poll
Advice On Next Mod
Old Dec 14, 2008 | 08:42 PM
JJAD's Avatar
Advice On Next Mod
Ok, so I have a SS 2.4 with the auto tranny
I already have a GMPP cold air intake and am wondering what would be my best choice for my next mod
Eibach Sportlines
Magnaflow Cat-Back
Header
what do you think guys?
help me out here!
Old Dec 14, 2008 | 08:48 PM
EXsoccer1921's Avatar
i wouldn't replace the header just yet, its not too restrictive. if you want to do somethiing with your exhaust get a dp and a catback, or just a downpipe.
as for springs, sportlines aren't too bad. but i think people get them just cause everyone else has them and says they are so great. but there are quite a few choices for lowering springs
Old Dec 14, 2008 | 09:00 PM
JJAD's Avatar
if you were going to suggest springs in that case which ones would they be?
Old Dec 14, 2008 | 09:36 PM
well i actually would get the sportlines, but because thats the drop i'm looking for. but there are other springs with different drops and ride qualities out there. i'm pretty sure gravana caries some, and A Plus Performance, and TTR and OTTperformance. just look in my sig haha. the ottp link doesn't work so just go to ottperformance.com
Old Dec 14, 2008 | 10:24 PM
TurboTechRacing's Avatar
Eibach sportlines
Old Dec 14, 2008 | 11:33 PM
JJAD's Avatar
yeah i've heard amazing things about them
sounds like thats the way i will go when i get springs!
Old Dec 15, 2008 | 08:15 PM
JJAD's Avatar
Old Dec 15, 2008 | 10:22 PM
iLLmaTic3s's Avatar
go w/ a catback...
magnaflow is a lil to loud for my tast..check out the gmpp
Old Dec 15, 2008 | 10:25 PM
dman090's Avatar
Originally Posted by iLLmaTic3s
go w/ a catback...
yah definatly the GMPP i LOVE mine
but i would choose sportlines
Old Dec 15, 2008 | 11:22 PM
JJAD's Avatar
thanks guys, is mangaflow really that much louder?
Old Dec 16, 2008 | 08:38 PM
JJAD's Avatar
Old Dec 16, 2008 | 08:40 PM
Bika's Avatar
Fail Less.
header and downpipe. biggest restriction removed.
then get a good tune to tweak your timing, afr, and auto trans shifting
Old Dec 16, 2008 | 08:44 PM
JJAD's Avatar
which would give me the best gain for $$
header or a cat-back
i'm also wondering which would allow the engine to rev quicker
Old Dec 16, 2008 | 09:11 PM
Bika's Avatar
Fail Less.
neither will allow you to rev quicker. the only thing that will make your engine rev quicker is taking weight off the engine's rotating assembly.
the biggest restriction in our exhaust has proven to be the manifold/downpipe. That should net you slightly more than just a catback.
Old Dec 16, 2008 | 09:16 PM
JJAD's Avatar
but the mass of the rotating assembly won't give me much if anything for HP correct?
Old Dec 16, 2008 | 09:55 PM
Bika's Avatar
Fail Less.
rotating assembly = crank, rods, pistons. you arent lightening any of that on that LE5 engine. rotating parts that draw off the engine's power also include wheels, crank pulley, and flywheel. those are more commonly replaced.
and no it doesnt "give" you horsepower, but it would "free up" lost horsepower by not using as much to turn the assembly and giving it less inertia. thats why it can rev / down rev quicker.
Old Dec 16, 2008 | 11:15 PM
JJAD's Avatar
thanks
that helps alot!
Old Dec 17, 2008 | 01:05 AM
davekicksyourass's Avatar
don't do a cat back just replace the muffler and the pipe from the rear axle back. Stock cat back is already 2.5 inch mandrel bent up to the rear axle. It narrows to 2.25 inch at the rear axle. Have a muffler shop cut the pipe there and replace with 2.5 in pipe at the rear axle and get a new muffler(any one as long as it's straight through. Get the header too. Pay less than you would for the whole cat back and get a better result. more bang for your buck. That's what I did.
If you still want the cat-back I wouldn't do the gmpp because it is 2.25 inch the whole way. What ever you do you want 2.5inch for your cat back(ex. magnaflow, megan, corsa, ark, or pacesetter if you want a cheap one)
In terms of springs, I have the ssc springs that zzp sells. I like them, they were a good value.
Old Dec 17, 2008 | 10:59 PM
JJAD's Avatar
so you figure i would pick up some extra HP from just the muffler?
Old Dec 18, 2008 | 12:31 AM
Bika's Avatar
Fail Less.
cant hurt, but its minimal gains. maybe like 5hp.
Old Dec 18, 2008 | 09:44 PM
JJAD's Avatar
yeah catback is still the best IMO
Old Dec 19, 2008 | 02:30 AM
I dropped 3 tenths from just a muffler in comparison to my car was running stock. Now maybe it was a better day or better conditions, but the runs were only a couple of weeks apart.
Old Dec 19, 2008 | 11:36 PM
JJAD's Avatar
3 tenths thats awesome!!
Old Dec 21, 2008 | 05:29 PM
JJAD's Avatar
bump if anyone is interested in giving more free advice
Old Dec 21, 2008 | 05:37 PM
SSMOKEM's Avatar
Get the springs, then people won't bother you with " drop it, it'll look better" line when you post pics of your car.
Also I suggest progress lowering springs, very nice ride, and low, or lower than sportlines. Also cheaper.
