Auto shifting question....
Old Jul 1, 2009 | 05:47 PM
LastAXEL's Avatar
Sorry if this has been discussed before but the search thing is horrendous... I tried..
When trying to take off quickly in an auto can you go from L to I to D to get better acceleration.
If so, how exactly do you do it?
sorry if this a noob question.. but I dont give no ****....
Old Jul 1, 2009 | 07:14 PM
diablo9287's Avatar
L is great for launching because of no traction control and you get a couple hundred more rpms out of 1st as well as a harder quicker shift into 2nd once in 2nd and still wot put the lever from L to I this will allow for the car to go into 3rd when needed and as far as D you dont really need to put it back into drive until you wanna go back to regular driving.
Old Jul 1, 2009 | 08:27 PM
LastAXEL's Avatar
do I have to take my foot off the gas to shift into I from L?
Old Jul 1, 2009 | 08:40 PM
diablo9287's Avatar
no just floor it in L and once its at about 6500 rpms it will shift into 2nd then once in 2nd just put it in I from L while still flooring it, you wont feel anything change except a t/c light on the dash. so no u dont have to take ur foot off the gas let the car do everything.
riko540's Avatar
umm I don't think so
Old Jul 1, 2009 | 08:53 PM
LastAXEL's Avatar
thats cool.. thanks
Old Jul 2, 2009 | 10:23 PM
justypontiacg5gt's Avatar
Uhhh in I it will tach out. You have to shift into drive cuz it will bounce off the rev limited.
Old Jul 2, 2009 | 11:00 PM
Red07SSNA's Avatar
As stated above in "L" it will automatically shift into second at redline and will stay in 2nd until you shift into "I". In "I" the tranny will shift into third and will down shift into 2nd and 1st as you slow down. You can leave it in "I" around town if you want to -- it keeps the tranny from shifting up into overdrive so gas mileage will suffer.
justypontiacg5gt "Uhhh in I it will tach out. You have to shift into drive cuz it will bounce off the rev limited. " -- My 2.4L was shifting from 2nd into third at 70+ MPH...what speed are you going to tach-out the rev limiter in 3rd?
Old Jul 2, 2009 | 11:03 PM
OrngBalt's Avatar
Halfcent did a how-to on launching an auto. that should help the search
Old Jul 2, 2009 | 11:04 PM
Spanky's Monkey's Avatar
for a better launch i suggest you brake torque, since you're going through the trouble.
Old Jul 3, 2009 | 06:51 AM
hailcesar75's Avatar
i was curious about this too. when i launch in L it goes to red line and then i shift into "I". i always took my foot of the pedal cuz i was to scared to find out .
Old Jul 3, 2009 | 10:28 AM
don't lift your foot bud. i've been launching and downshifting my auto for years now. 74K later and she never misses a shift and chirps taking second on the trifecta tune. you guys should play with that auto a little more it'll surprise the **** outta ya.
Old Jul 3, 2009 | 01:59 PM
diablo9287's Avatar
?? so did u put it into I before it went into 2nd or after?
Old Jul 3, 2009 | 02:13 PM
OrngBalt's Avatar
Guys, look at the How to. You start in Low and it will shift to second, then go up to I and it will shift to third. If you are launching for the track, you wont need more than that. You can drive like that because D only allows you to go up to the top gear for cruising.
Old Jul 3, 2009 | 02:39 PM
HunterKiller89's Avatar
i think he;s talking about banging off the rev limiter at the top of 3rd gear, but thats around 110mph]
and its an automatic guys, you never need to take your foot off the gas
Old Jul 4, 2009 | 12:38 PM
if you leave it in "I" and just keep speeding up it will not shift out of 3rd and it will hit the rev limiter until you shift it to drive. mine is taching out at like 90 maybe somewhere around there.
Old Jul 4, 2009 | 02:27 PM
diablo9287's Avatar
i think its quite a bit more than 90 by the end of third 110 maybe, its been a while so im not actually sure but i would think it would be around there.
Old Jul 4, 2009 | 02:29 PM
XgunsmokeX's Avatar
get B&M shiftplus+
Old Jul 5, 2009 | 10:23 AM
wordsthatiwrote's Avatar
Car isnt worth anything past 70. It has no get up and go. Im disappointed when I try to pass someone when Im doing 70.
Just leave your car in L and keep the pedal to the carpet and wait for the RPM to top out and then change to I. Ive had a few instances in which the car RPM guage bounced up and down cause of the redlining it.
If the car breaks, it breaks. THats the chance you take when running hard.
Old Jul 5, 2009 | 05:21 PM
i guess it depends on if you have a 2.2 or 2.4. The 2.4 has shorter gearing than the 2.2, but not THAT much shorter. it should still be redlining over 100mph
Old Jul 5, 2009 | 06:07 PM
blackbolt89's Avatar
time to get more bolt ons and a tune. i have plenty of power at 70
Old Jul 5, 2009 | 07:50 PM
Cant tune just yet. I dont want to cause my PAID warranty to be voided. Im sure they would try to say that the tune caused all the issues ( If i had any). I hear that the injectors are too small and the car runs rich from the factory. Is this correct?
Old Jul 5, 2009 | 09:19 PM
Mindrot's Avatar
No..
Old Jul 5, 2009 | 09:48 PM
Originally Posted by Mindrot
No..
yes...
check your facts before posting
Old Jul 5, 2009 | 10:50 PM
Red07SSNA's Avatar
You are unfortunately correct...when passing the car lacks power if you shift into "I" before you pass. It is best to punch it with the selector in "D". Makes no sense but if you try it you'll see.
