B&m Shift plus questions
Old May 14, 2009 | 12:40 PM
camshaft343's Avatar
I have a 2.4 Auto.
I want to get this. I DID find and read the thread about it but I had a couple questions that weren't answered.
I noticed that someone said they put there car in L...is that correct? Why?
Can the levels be switched while driving/car is on? or do you have to set it your prefered setting before you turn the car on?
Old May 14, 2009 | 12:42 PM
cobalt123's Avatar
i beleive you can go up in levels why its on but you have to turn it off to go down
rockstar014's Avatar
u can set it to 1 or 2 while the car is on and u know u can cherp them from L also
Old May 14, 2009 | 01:05 PM
But is it required to have the car in L while the shift kit is enabled?
Old May 14, 2009 | 01:15 PM
Red07SSNA's Avatar
No it is not reqired to have the tranny in low. However, it just makes sense to have it in "L" to turn off traction control so the ECM won't cut power if/when you get wheel spin. The tranny will upshift into 2nd on its' own at ~6500 RPM then shift into "I".
Old May 14, 2009 | 01:16 PM
ChevyRockstar's Avatar
No, when the car is on you can go up stages but not down.
Old May 14, 2009 | 01:42 PM
ok...what Is "I" just drive with traction control off?
Old May 14, 2009 | 01:48 PM
Turbo06Sedan's Avatar
L = No traction control, holds rpm regardless. Will upshift from 1-2. Wont upshift from 2-3.
I = Intense = Traction Control On, will only upshift if rpms are above 4k, but wont downshift unless rpms are below 2k. Will upshift 1-2, 2-3, 3-4.
D = Normal drive.
When racing, start in L. Towards top of 2nd gear, shift to I...stay in place for remainder.
I normally drive in I, as if I drive in D, it adds load onto the motor, which makes the turbo want to spool up by barely touching the gas, which in turn bogs the car down when the car is shitting 80psi of fuel, at 10% throttle going 30mph.
in I, its less load being a lower gear.
Old May 14, 2009 | 01:50 PM
you are wonderful
thank you! excited about getting it now
out of curiousity...how much roughly did you spen on your complete turbo build?
The turbo teck kit s is like 4Gs...i don't have that kind of cash
Old May 14, 2009 | 04:47 PM
If I were you, do what I wish I would of done.
Build your own, as essentially my kit is almost a custom setup.
However, buy the Garrett Kit, then get custom tuning.
Or if you want a complete turn key solution but still not break the bank, go with zzp.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
2009blackSS
Sep 30, 2015 05:57 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
