CA stainless steel header V2
Old Jan 9, 2008 | 02:15 AM
CobaltChikara's Avatar
I was just wondering if anyone has the new CA header yet. Is there any difference between the new and old ones(besides the new one being shinier), and any difference in power gains? I was thinking of replacing the stock manifold within the next month. Also would anyone that has one recommend the gm extrude honed manifold?
Old Jan 9, 2008 | 10:22 AM
pajinki's Avatar
As far as I knew, they only difference between the two is that v2 will fit on the 2.2 without modification. You gains depend on your other mods... I wouldn't expect more than 10HP at the crank for either.
Old Jan 9, 2008 | 02:39 PM
Brandon97Z's Avatar
It has a 3" collector as opposed to a 2.25" on the v1.
Old Jan 9, 2008 | 04:16 PM
wow 3" collector. that sounds like it would be great for F/I but for N/A...sounds like it might create too much loss of back pressure.
Old Jan 9, 2008 | 06:50 PM
Brandon97Z's Avatar
My thoughts exactly
Old Jan 12, 2008 | 11:24 PM
iLLmaTic3s's Avatar
exactly!!!! no need for 3" collector for a 2.2 or 2.4.that are not boosted.
Old Jan 13, 2008 | 07:49 AM
BigEMU1's Avatar
Just size it down with a 2.5" DP. Then you leave room for boost later if you're N/A.
Old Jan 13, 2008 | 07:56 AM
ecotecon18s's Avatar
the GM extrude honed mani is good if you dont want any warranty problems from the dealer...
Old Jan 13, 2008 | 11:09 AM
iLLmaTic3s's Avatar
yeah the only thing with the gm header..doesnt produce similar HP gain as the c/a header does.
Old Jan 13, 2008 | 11:10 AM
06blackg85ss's Avatar
truth
Old Jan 13, 2008 | 11:22 AM
iLLmaTic3s's Avatar
i mite do vs2 header but a 3" collector honestly guys isnt really needed for a n/a motor..much better for a s/c or t/c cobalt imo. stick with vs1 header and a 2.5 dp...thats wud ill be doing once i get my big bonus in from work..
Old Jan 13, 2008 | 12:47 PM
BigEMU1's Avatar
People seem to be doing well with the ZZP header. It's a 3" collector on both versions apparently... Besides, why bottleneck at a 2.25" collector into a 2.5" DP?
Old Jan 13, 2008 | 01:16 PM
cooljake73's Avatar
i got first ca header
Old Jan 13, 2008 | 02:04 PM
Brandon97Z's Avatar
Well 2.25 will net better low end tq then the 3", the gains up top you'd get from the 3" might not be enough to sacrafice down low. The 2.25 was the reason they dyno'ed the nice tq gain on the 2.4.
Old Jan 13, 2008 | 02:20 PM
firestorm's Avatar
the wife wants me to sell my gmpp exhaust manifold, and my ZZPcatless 3" stainless downpipe, with bung and flange for 2.5".
Old Jan 13, 2008 | 02:50 PM
BigEMU1's Avatar
I honestly can't see how increasing the size of the collector would be a drawback. Then why redesign it? The entire point of expanding your exhaust is to reduce your backpressure and make it more free flowing, at least until extreme points. As long as you keep the DP 2.5" this should be beneficial imo. I'd like to see a dyno comparison between the two.
Old Jan 13, 2008 | 03:02 PM
I'll probably go with the v1 header and 2.5 high flow cat downpipe combo since my warranty is already up. The 3" seems like overkill for the N/A, and i doubt i'll be boosted any time soon. I think the high end gain wouldn't be that much more, since it's N/A, it may not be worth that loss in low end tq. But yea i'm with you guys, i'd really like to see a dyno comparison between the two. That would help a lot of people with making their choices rather than trying to guess at what the gain difference would be. That new one sure does look purdy though .
Old Jan 13, 2008 | 09:29 PM
Brandon97Z's Avatar
It was origanlly dsigned with a 3" collector but they got the wrong sized flanges so they went ahead with it. it was designed for the ss/sc hence the 1.7" primaries and 3" collector. With a 2.5 downpipe you prolly wouldn't notice it that much but still a 2.5" collector and 2.5 downpipe would mate up and flow better.
Old Jan 14, 2008 | 12:19 AM
iLLmaTic3s's Avatar
yeah agreed with brandon..that wud ill be doing soon
Old Jan 14, 2008 | 11:06 AM
BigEMU1's Avatar
I agree completely, but good luck finding a header with a 2.5" collector. The only one I've found is the Vibrant and its a 4-2-1 step long racing header, not particularly my cup of tea. Plus there's not even an option for ceramic coating.
Old Jan 14, 2008 | 01:04 PM
Brandon97Z's Avatar
Yeah i know there's not a lot on the market since most are designed for the ss/sc. But i believe clear images 4-2-1 is a 2.5 along with ceramic coating, as thats the route i plan on going.
Jan 12, 2016 12:01 AM
nathan112i
Sep 30, 2015 07:12 PM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
