Catless DP question.
Old Apr 16, 2009 | 01:34 PM
Turbo06Sedan's Avatar
Before you flame, I didnt search beforehand. So..dont tell me too.
Question,
The 2.4's (other models might be different) have 2 o2 sensors.
1 pre cat, 1 pro cat.
I know the pre cat is the one that adjusts the computer to do..what it needs to do.
The 1 pro cat, from what i've read basically tells you if your cat is fubar'd.
With that said.
Could you get a pipe welded in its place (of the cat) without it throwin codes? If so, what does it throw?
a CEL/TC light? a hidden obd2 code(that doesnt trigger any lights on the dash)
Thanks in advance
Old Apr 16, 2009 | 11:28 PM
TCASON's Avatar
Question,
With that said.
Thanks in advance
No, it will throw an insufficiency cat code, CEL on your dash.
If you get an aftermarket tune, it can be tuned for not having the cat, and will not leave you with a CEL
Old Apr 16, 2009 | 11:29 PM
Red07SSNA's Avatar
No, you cannot get rid of the cat without getting emission codes. The cat changes the carbon monoxide to carbon dioxide and reduces nitrides of oxygen (like i know - I'm regurgitating what is written). You will get a CEL that your cat is insufficiant (don't have the codes handy). Some are having success getting rid of the cat and installing an elbow that moves tha HO2S2 sensor out of the flow to keep from getting CELs/SESs/MILs.
Pre cat = HO2S1
pro cat = HO2S2
Old Apr 17, 2009 | 12:50 AM
mmcgee123's Avatar
good old po420 get a tune that's what I did
Supercharged06SS
Dec 11, 2022 04:47 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Bohb
Sep 27, 2015 09:11 PM
